POV-Ray : Newsgroups : povray.animations : Imagemap on a curving surface Server Time: 6 Sep 2008 18:51:41 GMT
  Imagemap on a curving surface (Message 1 to 3 of 3)
Subject: Imagemap on a curving surface
Date: 9 Nov 2007 19:55:00
Message: <web.4734ba756f745ace460dd7020@news.povray.org>
I am not particularly skilled at this, so I may be going about this all wrong,
but I am attempting to make an animation of a softcover book opening (just the
cover, really).  I used a bezier patch and manually adjusted the control points
for each keyframe to create the animation, but the imagemap that I use for the
book's cover image (including the title) doesn't bend with the patch.  Is there
a way to attach the image to the surface so they deform together, or is there
perhaps a better way to do this altogether?
Subject: Re: Imagemap on a curving surface
Date: 9 Nov 2007 22:10:07
Message: <4734dabf$1@news.povray.org>
Add the keyword 'uv_mapping' to the pigment. On bezier patches, it Just
Works (tm).
Date: 10 Nov 2007 02:45:00
Message: <web.47351ad5d6e182d2b9ad0a790@news.povray.org>
> Works (tm).
That does indeed attach the image to a patch.  It has some odd behavior, though.
 I'm using Moray as my modeller, and was originally using a bezier patch that
was more than one sheet, as the spine of the book has a sharper curve.  Moray
does this by unioning patches together, but UV_mapping forces the image to
attach to each base patch, even when the texture is applied to the union.  This
results in the image being tiled across the complete surface.
I'm attempting to see if I can use a single patch, but if the control points are
moved too much to one side (so that they are not evenly spaced), the image warps
correspondingly, becoming squished on one side.
Copyright 2003-2008 Persistence of Vision Raytracer Pty. Ltd.
