Magnatune: We Are Not Evil
  POV-Ray : Newsgroups : povray.animations : Leaving a Trail Server Time: 16 Oct 2008 02:12:56 GMT
  Leaving a Trail (Message 1 to 8 of 8)
Subject: Leaving a Trail
Date: 18 Jun 2007 20:05:01
Message: <web.4676e46ef2941a4139928d3a0@news.povray.org>
I am currently working on a model of the solar system. Is there a way to
make the planets leave a trail as they move and/or define an elipse in the
shape of the orbits? I'm using astronomically correct formulae to calculate
the planetary positons, so just cylinders or tori won't work.
thanks,
OpalPlanet
Subject: Re: Leaving a Trail
Date: 18 Jun 2007 20:34:40
Message: <4676ec60$1@news.povray.org>
> to make the planets leave a trail as they move and/or define an
> elipse in the shape of the orbits? I'm using astronomically correct
> formulae to calculate the planetary positons, so just cylinders or
> tori won't work.
If you place a sufficiently large number of tiny spheres along your path, it
will look like a solid tube or string that follows your path. You can place
then using a #while loop.
Alternatively you can look into sphere_sweeps with a sifficiently large
number of control points along your path, again placed with a #while loop.
Rune
http://runevision.com
Date: 18 Jun 2007 20:55:01
Message: <web.4676f0c2ca61a70e6421e73c0@news.povray.org>
A merge or union of cylinders will most probably give better results in less
render time than both methods described above (all might be worth a try
though)
Regards Roman
Date: 19 Jun 2007 00:56:22
Message: <467729b6$1@news.povray.org>
> in less render time than both methods described above (all might be
> worth a try though)
Yes, agreed. I don't know why I forgot about that option.
Merge can be very slow with a high number of objects though, so if a
semi-transparent path is desired, sphere_sweeps may be faster after all,
though I haven't compared results myself. If a semi-transparent path is not
needed, union should definitely be used rather than merge.
Rune
Date: 19 Jun 2007 16:55:02
Message: <web.46780982ca61a70e39928d3a0@news.povray.org>
Rune, I was poking around your website and I found the particle system.
Could I just make each of the planets an "emitter" and leave a trail that
way?
-OpalPlanet
> > worth a try though)
> Rune
Date: 19 Jun 2007 19:00:01
Message: <web.467826ffca61a70e39928d3a0@news.povray.org>
I think sphere_sweep would work better, but i am having difficultly placing
the control points. I have .txt data files with <t,x,y,z> data for all the
planets, and i wanted to read that in and use each pint as one of the
control points. I'm new to this, but here is my best go at using a while
loop:
//to make the paths
#declare pathcount=1;
#while(pathcount <= num_planets)
  #switch(pathcount)
    #case(1)                  //Mercury
      #declare n = 0;
      #while( n < cnt)
       #read(mercury,tt,xx,yy,zz)
       #declare n = n +1;
      #render concat("Read up to file line ",str(n,6,0),"n")
   #break
    #case(2)                  //Venus
      #declare n = 0;
      #while( n < cnt)
       #read(venus,tt,xx,yy,zz)
       #declare n = n +1;
    #break
    #case(3)                  //Earth
      #declare n = 0;
      #while( n < cnt)
       #read(earth,tt,xx,yy,zz)
       #declare n = n +1;
   #break
   #case(4)                  //Mars
      #declare n = 0;
      #while( n < cnt)
       #read(mars,tt,xx,yy,zz)
       #declare n = n +1;
    #break
 sphere_sweep {
 quadratic_spline cnt,
 #declare n = 0;
 #while ( n<=cnt)
 <xx,yy,-zz>, .01
 #declare n = n +1;
  tolerance 0.1
  texture{pigment {White}
 finish {ambient 1}
 no_shadow
 #declare pathcount = pathcount +1;
#end//end paths
Obviously, not working.
Help, please?
OpalPlanet
> > worth a try though)
> Rune
Date: 20 Jun 2007 10:15:39
Message: <4678fe4b$1@news.povray.org>
> placing the control points. I have .txt data files with <t,x,y,z>
> data for all the planets, and i wanted to read that in and use each
> pint as one of the control points. I'm new to this, but here is my
> best go at using a while loop:
>  #switch(pathcount)
>    #case(1)                  //Mercury
>      #declare n = 0;
>      #while( n < cnt)
>       #declare n = n +1;
>      #end
>   #break
Hmm.
What is tt, xx, yy and zz ? They would need to be arrays when you want to
store many points in them.
So you would #declare xx, yy, zz and tt as arrays with size cnt (I presume
cnt is #declared elsewhere).
Then you'd use:
       #read(mercury,tt[n],xx[n],yy[n],zz[n])
And when you want to use the points:
 #while ( n<cnt)
 <xx[n],yy[n],-zz[n]>, .01
 #declare n = n +1;
I'm a bit rusty with File I/O in POV-Ray, so perhaps someone can correct me
if I'm wrong.
Rune
Date: 20 Jun 2007 10:21:58
Message: <4678ffc6@news.povray.org>
> system. Could I just make each of the planets an "emitter" and leave
> a trail that way?
Yes, that would be possible, depending on what effect you want. But then you
need to know the emitters' positions at any given point in time - not just
the current clock value. The particle system need to know the positions at
other lock values than the current one to work correctly. This may be
cumbersome if you get your positions from a list of points. On the other
hand, you could load all the points into a spline function and use that one
for the emitter positions.
Rune
Copyright 2003-2008 Persistence of Vision Raytracer Pty. Ltd.
