POV-Ray : Newsgroups : povray.animations : ImageMagic batch convert syntax? Server Time
14 Mar 2026 14:10:46 EDT (-0400)
  ImageMagic batch convert syntax? (Message 1 to 3 of 3)
Subject: ImageMagic batch convert syntax?
Date: 14 Feb 2000 19:31:41
Message: <slrn8ah6ki.289.sjlen@zero-pps.localdomain>
Hi all
I've been battling all day trying to get the batch convert
syntax right for ImageMagic for Linux.
I've tried what looks obvious from the docks such as
$ convert strobe*.png PPM:strobe*.ppm
$ convert strobe???.png ppm:strobe???ppm
the input section works but the output doesn't.
I've tried a bash script found in a book 'Running
Linux, O'reilly'.
The syntax they give is as follows character for
character:
do
convert $i xpm:'basename $i .bmp' .xpm
done
I've put my own file types in and file names etc, and
tried many variations on this theme but nothing seems
to work, at one point it completely filled the HD which
has 2G free space on it, other times it'll say input file
not found etc, etc.
I'd be grateful if anyone could come up with a solution, I'm
even considering getting the old version on Megapov and
rerendering the whole 216 frames in the correct format,
the photons in 0.4 are totally different, it only took 5
days to render last time.
 12:00am  up 11:03,  5 users,  load average: 1.25, 1.07, 1.10
Subject: Re: ImageMagic batch convert syntax?
Date: 15 Feb 2000 00:38:46
Message: <ouKoON6D=NmusjrAAl=Z7M47gKtn@4ax.com>
On 14 Feb 2000 19:31:41 -0500, sjl### [at] ndirectcouk (Steve) wrote:
>Hi all
Steve,
try this:
for i in *.bmp; do convert $i `basename $i bmp`xpm; done
It worked here. And mind the backticks.
Peter Popov
pet### [at] tagpovrayorg
ICQ: 15002700
Date: 15 Feb 2000 16:45:01
Message: <slrn8aijje.35v.sjlen@zero-pps.localdomain>
>>Hi all
>Steve,
>try this:
Thanks Peter, it worked.  The main thing I got wrong was I
was changing basename to the name of the files ie strobe02
as the files went from strobe02000 to strobe02216.png.
One to be stored in the useful.doc.
 12:52pm  up 23:55,  4 users,  load average: 1.20, 1.09, 1.05
