POV-Ray : Newsgroups : povray.animations : Scripts for Controlling a Render Farm Server Time
13 Jul 2026 19:53:38 EDT (-0400)
  Scripts for Controlling a Render Farm (Message 1 to 10 of 11)
Subject: Scripts for Controlling a Render Farm
Date: 30 Jan 2020 09:50:01
Message: <web.5e32ec85d288f9963774b87b0@news.povray.org>
I'm just getting ready to write up some scripts to automatically distribute an
animation job between a number of Windows computers (probably Azure VM's).
Before I get too far I thought I'd check if someone else has set something like
this up already.
Up to now I've been manually creating a separate .INI file for each machine and
assigning it a portion of the job based on the machine's speed. This gets a bit
tedious after a while and makes it difficult to add and remove computers on the
fly.
Subject: Re: Scripts for Controlling a Render Farm
Date: 30 Jan 2020 11:30:00
Message: <web.5e33035f31cc7d453774b87b0@news.povray.org>
I've hit my first glitch in this process. Years ago I did something similar by
having a script call povray.exe for each frame to render. povray.exe would not
exit until the render of the frame was complete. After povray.exe returned the
script could pick the next frame to render and continue. The current
pvengine32/64.exe program runs asynchronously and returns immediately so the
script can't tell when the render is finished. Also, once pvengine is open you
can't call it again with another .ini file to start another frame.
Any ideas?
Date: 30 Jan 2020 12:35:01
Message: <web.5e3313ad31cc7d4528c55bc90@news.povray.org>
hi,
> Any ideas?
on a *nix-like box, your script could, for instance, use 'ps' to see whether
POV-Ray is still running.  maybe the Windows Ubuntu sub-system thing provides
such tools?
regards, jr.
Date: 30 Jan 2020 12:55:00
Message: <web.5e33183731cc7d453774b87b0@news.povray.org>
"jr" <cre### [at] gmailcom> wrote:
> hi,
> > Any ideas?
> such tools?
> regards, jr.
Unfortunately the pvengine never terminates unless the user manually close it.
Date: 30 Jan 2020 13:10:00
Message: <web.5e331b7031cc7d4528c55bc90@news.povray.org>
hi,
> > > Any ideas?
> > such tools?
> > regards, jr.
not even when your ini file contains 'pause_when_done = off' ?
regards, jr.
Date: 30 Jan 2020 14:00:00
Message: <web.5e33269031cc7d454eec112d0@news.povray.org>
Can you use something like:
Post_Scene_Command=taskkill /f pvengine32/64.exe
in your .ini?
http://wiki.povray.org/content/Reference:Shell_Command_Options#Shell_Command_Sequencing
https://techieinspire.com/how-to-start-and-end-or-kill-process-using-dos-command-prompt/
Date: 30 Jan 2020 18:21:40
Message: <5e336504$1@news.povray.org>
Am 1/30/20 12:53 PM, also sprach Steve Anger:
>> hi,
>>> Any ideas?
>> such tools?
>> regards, jr.
I have povconsole.exe which does what you want.  A gui-less version that
I drive from my renderfarm.  It's a little old since I switched my farm
to all linux and haven't needed to update it.
http://www.buckosoft.com/povclipse2/povray/
dik
Rendered 49,882,521,600 of 49,882,521,600 pixels (100%)
Date: 31 Jan 2020 09:35:00
Message: <web.5e343a5f31cc7d453774b87b0@news.povray.org>
> dik
Was there an official source release for that or was it a version you customized
yourself? I need to use povray-3.8.0 since it corrects a rendering bug that
existed in the older versions. If you have the source I could update it with the
latest code.
Date: 31 Jan 2020 10:54:36
Message: <5e344dbc$1@news.povray.org>
Am 1/31/20 9:31 AM, also sprach Steve Anger:
>> dik
> latest code.
It is the official source.
 From memory, so I'm likely wrong:
In VS2015 load povray.sln.  Enable subproject Console, disable
subproject Gui.
Build it.
It will complain that you need to #define _CONSOLE somewhere, and tell
you where. (Hint: in my copy it's at
windows/povconfig/syspovconfig.h:54:// _CONSOLE must be defined when
building the console version of POVWIN.
windows/povconfig/syspovconfig.h:56:// #define _CONSOLE
So do that and rebuild.
et voilà!
dik
Date: 1 Feb 2020 14:55:06
Message: <web.5e35d70031cc7d453774b87b0@news.povray.org>
> subproject Gui.
> Build it.
> et voilà!
> dik
Sounds great. Thanks!
