POV-Ray : Newsgroups : povray.animations : ttso WIP Server Time
27 Jul 2024 14:33:28 EDT (-0400)
  ttso WIP (Message 1 to 8 of 8)
Subject: ttso WIP
Date: 27 Sep 2018 02:35:35
Message: <5bac7a37$1@news.povray.org>
Through the Space of ...
http://www.buckosoft.com/tteoac/video/testRenders/ttso-480p.mp4
I wasn't going to post this yet, but
On 09/27/2018 12:09 AM, Kenneth wrote:
> it would be interesting
> to construct a plot of distance values (as seen in the preview render,
> horizontally for example) with the camera angle changing all the way
from 1 to
> 90(!)
I was having Fun With Aspect Ratios. At 40 seconds, the bit where the
monitor shrinks away, rather than slide the video down, I changed the
camera so that the video fits the changing rectangle.
The aspect ratio of the caboose slides from 1.69 to 141.40
dik
Rendered 1024 of 921600 pixels (0%)
Subject: Re: ttso WIP
Date: 27 Sep 2018 02:46:35
Message: <5bac7ccb$1@news.povray.org>
You made my day! :-D
Brilliant!
Date: 27 Sep 2018 02:55:07
Message: <5bac7ecb@news.povray.org>
Glad you did. It is good.
Regards
Date: 27 Sep 2018 14:55:01
Message: <web.5bad268952ce6ec6a47873e10@news.povray.org>
Ha! That is really cool. Is the first half of the animation a *single* render
within POV-Ray, with the multiple panes all rendered at once?? If so, I must
have missed the 'how-to' explanation in the past.
I still like that 'rocket exhaust' method you use!
In the second half, I can't say that I understand what the on-screen numbers
represent-- but it looks interesting nonetheless ;-)
Date: 27 Sep 2018 15:18:57
Message: <5bad2d21$1@news.povray.org>
> represent-- but it looks interesting nonetheless;-)
Bars and beats?
Regards
Date: 29 Sep 2018 17:56:15
Message: <5baff4ff$1@news.povray.org>
No, it is 3 renders.  I do Camera2 and Camera3 and then run the main
scene. (Years ago, Warp(?) did an animation with 4 camera angles in a
single render. Maybe that was uberpov?)
Like Stephen said, bars and beats.  When I start a scene, I first run
the DebugBeats version to get the timing of the scene together.  When
the drum machine was on, it was fairly easy; "number of beats / time +
occasional drift".  Now that the drum machine is off ... mathematically
I sucked at holding tempo on the keyboards. :), the retard and hold were
especially tricky to work through.
The hardest part for me is looking at the numbers.  Musicians count
1-2-3-4 and C style arrays count 0-1-2-3.  After 15 years, I see that
"3" and still think it's the middle of the measure, not the 4th beat.
I care because direct.inc contains the timings like this:
#declare Countdown10Start	= Measure(326,2);
#declare Countdown10End		= Measure(327,0);
#declare Countdown9Start	= Measure(327,0);
#declare Countdown9End		= Measure(327,2);
#declare Countdown3Start	= Measure(327,2);
#declare Countdown3End		= Measure(328,0);
#declare Countdown2Start	= Measure(328,0);
#declare Countdown2End		= Measure(328,2);
#declare Countdown1Start	= Measure(328,2);
#declare Countdown1End		= Measure(329,0);
"0" is easy, but I'm always typing "3" for the middle of the measure
instead of the correct "2".
(Btw, the original launch sequence countdown was 10-9-5-6-1 because the
kid can't count yet.)
dik
Date: 29 Sep 2018 17:58:52
Message: <5baff59c$1@news.povray.org>
Oh, the image that I posted in p.b.i was the last frame of Camera2 which
has an extreme aspect ratio, 140:1, but rendered at 500x500, hence the
really tall spheres.
dik
Date: 30 Sep 2018 02:34:12
Message: <5bb06e64$1@news.povray.org>
Am 29.09.2018 um 23:56 schrieb dick balaska:
Probably MegaPOV. That one had a camera pigment.
