POV-Ray : Newsgroups : povray.animations : Double Pendulum Animation Server Time
28 Jul 2026 10:24:48 EDT (-0400)
  Double Pendulum Animation (Message 1 to 9 of 9)
Subject: Double Pendulum Animation
Date: 30 Jun 2018 05:58:33
Message: <5b375449$1@news.povray.org>
First basic implementation of "Double Pendulum" mouvement.
Check out at <http://louisbel.free.fr/animate/>
Your comments are welcome.
Kurtz le pirate
Compagnie de la Banquise
Subject: Re: Double Pendulum Animation
Date: 30 Jun 2018 06:29:48
Message: <5b375b9c$1@news.povray.org>
On 30/06/2018 10:58, kurtz le pirate wrote:
> Hi,
Nice! Now using reflective spheres. :-)
Regards
Date: 30 Jun 2018 08:20:01
Message: <web.5b37746a563987a3458c7afe0@news.povray.org>
kurtz le pirate <kur### [at] gmailcom> wrote:
> Hi,
This is very nice!
How long did it take you implement the code?
I'm glad to see that you're another person playing with the coding challenge
topics   :)    There's lots of fun and educational projects there.
(I still have to fix the last problem I had with converting the Perlin noise
flow field
Coding Challenge #24: Perlin Noise Flow Field
https://www.youtube.com/watch?v=BjoM9oKOAKY
I've always wanted to play with some of these systems and have the colors change
as a function of tension, rotational or translational velocity, etc.
1000 frames is "a lot" (Shut it, Balaska)
How long to render the whole animation?
Date: 30 Jun 2018 08:23:22
Message: <5b37763a$1@news.povray.org>
LOL
Regards
Date: 30 Jun 2018 11:12:32
Message: <5b379de0@news.povray.org>
Le 30/06/2018 à 14:15, Bald Eagle a écrit :
> This is very nice!
> flow field
Yes, Coding Challenge is a good source of inspiration...
The code took me about 1 hour. The tricky part was the persistence of
the data between images. Then, 1000 frames, 800x600 with anti-aliasong
take 15mn.
Kurtz le pirate
Date: 2 Jul 2018 08:55:01
Message: <web.5b3a205c563987a3be7517870@news.povray.org>
> > This is very nice!
> > flow field
> take 15mn.
> Kurtz le pirate
I'm guessing what you were passing between frames were the two angles and
angular velocities in order to do a numerical solution of the ODEs. However, I
think your numerical solution scheme is adding energy. You start off with the
balls both stationary and horizontal. Later in the motion BOTH balls are above
the horizontal. A numerical scheme to conserve energy is surprisingly difficult.
What scheme did you use?
Even more surprisingly, there are complex double pendulum motions that are
periodic, many that are symmetric, but several that are asymmetric. Would you
like some data for one (or more) of those motions?
Jim T.
Date: 2 Jul 2018 09:37:13
Message: <5b3a2a89$1@news.povray.org>
> the horizontal.
I noticed this too.  But then later they resolve back towards 0. I
figured the added energy was on purpose for effect.
Welcome to the dark side, where animations are greater than 1 second
long, Mr. le pirate.
:D
dik
Rendered 328976 of 330000 (99%)
Date: 7 Jul 2018 11:08:33
Message: <5b40d771@news.povray.org>
yes and the last <x,y> position
> However, I think your numerical solution scheme is adding energy. You start off with
the
yes, energy is used but... it's not MY scheme.
In this example, I just adapted the L3 Processing code to POVRay SDL.
And, has i say on my web page, this not a real simaultion.
If systems of equations defining motion are not too complicated, why not.
Kurtz le pirate
Date: 7 Jul 2018 15:05:00
Message: <web.5b410ec1563987a3458c7afe0@news.povray.org>
IIRC, a double-pendulum is featured somewhere in this movie:
http://www.chaos-math.org/en
Which means that there may be existing code for one somewehere...
Or contact the movie-makers - they may be able to point you in the right
direction.
