POV-Ray : Newsgroups : povray.animations : ttlo Server Time
24 Apr 2024 22:18:02 EDT (-0400)
  ttlo (Message 1 to 8 of 8)
Subject: ttlo
Date: 1 Apr 2018 21:21:14
Message: <5ac1858a$1@news.povray.org>
Elvis has left the building.
My next scene, Through the Liftoff of ...
http://www.buckosoft.com/tteoac/video/testRenders/ttlo-720p.mp4
dik
Rendered 328976 of 330000 (99%)
Subject: Re: ttlo
Date: 2 Apr 2018 19:25:01
Message: <web.5ac2bbb36c6fec7aa47873e10@news.povray.org>
Wow! You've certainly been busy. I especially like the playful-looking smoke
from the train's engine, AND the clever way you made the rocket (er, train)
exhaust as it launches and lifts into the sky. Your animated patterned-sphere
technique is looking better and better.
Well done!
(BTW, the video didn't come up immediately-- it was taking it's time loading or
something-- but on my 2nd try, I waited patiently and it finally showed up.)
Subject: Re: ttlo
Date: 3 Apr 2018 02:59:37
Message: <5ac32659$1@news.povray.org>
195km??? And still visible from the ground???
I love this scene! I thought the locomotive would travel along the
tracks but this is better. Well done. Cannot wait to discover the
destination.
Subject: Re: ttlo
Date: 3 Apr 2018 06:13:38
Message: <5ac353d2$1@news.povray.org>
Thanks. I like that too. I hadn't thought of the term "playful-looking"
but that's a good description. It is a bug that caused it to sputter,
but I really liked that. (I underestimated MaxThrusts).
It is getting there. I think I need logarithmic curve for the
fade-to-clear. .999 becomes .9999 becomes .99999 etc.
> Well done!
Thanks!
dik
Subject: Re: ttlo
Date: 3 Apr 2018 10:52:09
Message: <5ac39519$1@news.povray.org>
Very small km?
On the other side of that, I think it is 10km and hasn't even cleared
the strongback.
I was worried you spacegeeks would freak out about that. :)
In my defense, in some reality, the SpaceLoco is being carried by the
kid and is really no higher than an outstretched arm, 4 feet up. :)
The speedometer/tachometer sweep is what I used to see going from 0-100
mph (in 6 seconds) on my CB650sc. Other than that I didn't put a lot of
control into the numbers. I wasn't sure where they'd end up.  I will
figure out what I want those numbers to be and backport the increments
to fit. -- I just watched yesterday's SpaceX launch; I need to really
dial back the altitude and increase the speed. :)
Major math disaster strikes!
So I have this 16:43 long song/movie.  I break out a scene of a couple
of verses, between 1 and 2 minutes, and work on that.
The problem is, each scene can not end exactly on a frame, because I
support 23.976 and 30 fps, and because I was a little sloppy. Each scene
is +-0.5 frames off, which added up over the scenes. Even worse, in the
movie, I have different start times for this scene depending on frame
rate. :(  I am off by 0.126 seconds from where I think I am, which is
horrible when trying to time it to music.
This is a cumulative problem, and I never really noticed it because most
music cues happen on the peak of a sin curve, so if it is off by a
little it's not really noticeable.  But, this scene, the countdown,
monitor2 on and monitor3 on all need to nail the timing.  And in this
scene as presented here, they do.  But, when I pasted it into the full
movie, it is off by 0.126 seconds and they look horrible.  Even worse,
this is 30 fps, and the 23.976 fps edition has a different amount of
off-ness. [1]
So I have to do this scene in two different lengths. In the ini I pass
Declare=__FPS__=30
and adjust the duration and start time of the scene accordingly. :) :(
And, the Thrusts and camera2/3 images are handled by Java [2] and *it*
needs to know the different scene durations and start times.  Just ugh.
At least at the end of this scene, my two timelines are resynced back up.
Math, and time, are most unforgiving mistresses.
> destination.
I'm not real sure.  Do I go into space? Do I fly around the room? both?
I cut the next scene at 2:13, which is my longest scene, and I'm not
sure what to do with it. :)
dik
[1]
http://git.buckosoft.com/gitweb/pov.cgi?p=tteoac.git;f=ttCommon/Storyboard.txt;hb=HEAD
(lines 59-60)
[2] http://www.buckosoft.com/javadoc/TteoacService/
Subject: Re: ttlo
Date: 4 Apr 2018 02:47:10
Message: <5ac474ee$1@news.povray.org>
> Very small km?
> the strongback.
Just ignore them. No imagination at all. ;-)
In fact I think it is a brilliant feature. It throws people into
confusion as they are caught by the action and forget the /reality/ of
the playground. I was caught myself...
Of course!
Or not. There is a real nice feeling about going into space at a
comfortable 40 km/h.
> off-ness. [1]
> Declare=__FPS__=30
I guess the number or grey hairs on your head are increasing (or falling
out instead) exponentially. :-)
>> Well done. Cannot wait to discover the destination.
I am sure all will be clarified in due time. I have full confidence on
the issue.
Subject: Re: ttlo
Date: 4 Apr 2018 14:51:49
Message: <5ac51ec5$1@news.povray.org>
Hmm, I used to drive Zürich to Basel at 140 km/h, so that number is
significant to me, and it's 3 digits. So, that's my target. Thanks! :)
(Or maybe I'll stick to the posted speed limit of 120 ;) )
Now that I've straightened this out, I wish I had done it sooner. The
solution is separate ini files and different times for each edition
(frame rate).  A tiny bit more tedious to set up, but way easier to
manage and infinitely more accurate.
My Slovak stock is blessed with perdurable hair. And being blond, you
can't even see the grey. :)
> the issue.
This is interesting (to me). For the first 5 years (1999-2003) I
finished 1.2 minutes of animation a year.  The last 2.5 years since I
picked this back up, my throughput is 2.1 minutes of animation a year.
I have 5.5 minutes left to do.  If I can keep up this pace, I am
targeting a Christmas 2020 finish date. :)
dik
Subject: Re: ttlo
Date: 4 Apr 2018 15:08:32
Message: <5ac522b0$1@news.povray.org>
Am 04.04.2018 um 20:51 schrieb dick balaska:
As a nitpicking realism fanboy, I advocate paying attention that the
altitude increases properly in accordance with the speed. Dunno if
that's currently the case for your video, just putting it out there.
