POV-Ray : Newsgroups : povray.animations : How to fix texture to moving part Server Time
17 May 2026 07:14:35 EDT (-0400)
  How to fix texture to moving part (Message 1 to 10 of 11)
Subject: How to fix texture to moving part
Date: 7 Oct 2013 07:55:00
Message: <web.52529e927ce0c7bc1a5bae550@news.povray.org>
Hi, all!
I have a code with a cylinder that tilt both sides like an inverted pendulum and
it is textured with rust iron.
The problem is that when it tilts, each picture has a diferent rust texture.
This is the texture used in the cylinder:
#declare Rust =
        granite
        color_map {
            [0.0 rgb <0.4, 0.3, 0.18>]
            [0.4 rgb <0.3, 0.0, 0.00>]
            [0.5 rgb <0.3, 0.2, 0.04>]
            [0.6 rgb <0.1, 0.1, 0.14>]
            [1.0 rgb <0.4, 0.3, 0.14>]
    finish { ambient 0.1 diffuse 0.3 }
cylinder{
    <0, 0, 0>, <0, 50, 0>, 1
    texture{Rust scale 10 finish{roughness 100 ambient 0.2 }
    rotate Ang*z // Ang = tilting degree
Question: Is there any code so the cylinder has the same texture in all frames?
Thanks in advanced for your help.
Subject: Re: How to fix texture to moving part
Date: 7 Oct 2013 15:40:00
Message: <web.52530d075b3e3e64ef0c5fed0@news.povray.org>
"Janc" <jan### [at] telefonicanet> wrote:
> Hi, all!
> #declare Rust =
> texture {
>     pigment {
>         granite
>         color_map {
> cylinder{
You have a missing bracket "}" to close the texture before the rotate I think.
So the texture is rotated and not the cylinder what seems to be your intent.
Best regards,
Michael
Date: 7 Oct 2013 16:10:01
Message: <web.525314f35b3e3e64b9bbbc460@news.povray.org>
> > Hi, all!
> > #declare Rust =
> > texture {
> >     pigment {
> >         granite
> >         color_map {
> > cylinder{
> Best regards,
> Michael
Hi! Michael.
Thanks for your help, but it was a problem of copy and paste, I missed the last
Any way, povray should refuse to work if there is a lost }
cylinder{
    texture{Rust scale 10 finish{roughness 100 ambient 0.2 } }
Date: 7 Oct 2013 16:50:00
Message: <web.52531de35b3e3e64ef0c5fed0@news.povray.org>
> Hi! Michael.
Usually it does. But in some cases the placement of the brackets determines the
structure the transforms are to be applied. Textures can be transformed as well
as objects. So if you have a transform (like rotate, translate or scale or the
totally confusing matrix transforms) within a texture, it will be applied to the
texture and not to the object which the texture is to be applied.
> cylinder{
In this case the rotation is applied to the object (the cylinder) and not to the
texture.
Best regards,
Michael
Date: 8 Oct 2013 06:51:01
Message: <5253e395@news.povray.org>
Actually, with the code you posted it would have complained
   "Parse Error: No matching } in 'cylinder', End of File found instead"
So you probably "fixed" it at the wrong place by adding a "}" later.
Date: 8 Oct 2013 07:00:01
Message: <web.5253e57d5b3e3e64bbbff5b50@news.povray.org>
> > Hi! Michael.
> > cylinder{
> texture.
> Best regards,
> Michael
Hi! Michael.
I tried with various position of "rotate<x,y,z>" but it never seem to rotate my
Rust texture.
#declare MyRust =
    texture{ Rust
        normal { agate 1.5 scale 0.25 }
        finish { phong 0.1  }
        scale 0.1
#declare Mastil =
    union{
        cone {
            <0, 0, 0>, radio_inferior_mastil   // Centro y radio inferior.
            <0, 320, 0>, radio_superior_mastil    // Centro y radio superior.
            open
        cylinder{ // Lower end closer.
            <0, -.5, 0>, <0, .5, 0>, radio_inferior_mastil
Test 1
object{
    Mastil
    #local Ang_Mastil = -( ((ClockZ-Fase_2)*90)/(Fase_3-Fase_2) );
    rotate <0, 0, Ang_Mastil> // OK
    texture{ MyRust rotate <0, 0, Ang_Mastil> } // <<<<<< it seems not rotate.
Test 2
object{
    Mastil
    texture{ MyRust } // <<<<<< it seems not rotate.
I upload a gif with the result at:
http://news.povray.org/povray.binaries.animations/thread/%3Cweb.5253e42b5b3e3e64bbbff5b50@news.povray.org%3E/
There you can see how texture change each frame.
Regards.
Date: 8 Oct 2013 13:10:00
Message: <web.52543bb75b3e3e64f1cbbe240@news.povray.org>
 Hi Janc,
see your p.b.a for my idea what happens here.
Best regards,
Michael
Date: 8 Oct 2013 15:50:01
Message: <web.525460d25b3e3e64a9639f950@news.povray.org>
>  Hi Janc,
> Best regards,
> Michael
I'm sorry, Michael, I don't understand you about:
"see your p.b.a for my idea what happens here."
I keep testing with rotate.
Regards.
Date: 9 Oct 2013 02:20:01
Message: <web.5254f4805b3e3e64b47623b00@news.povray.org>
> >  Hi Janc,
> > Best regards,
> > Michael
> Regards.
Sorry,
I meant your p.b.a.-thread where you posted your animation.
Best regards,
Michael
Date: 9 Oct 2013 02:20:02
Message: <web.5254f5365b3e3e64b47623b00@news.povray.org>
> >  Hi Janc,
> > Best regards,
> > Michael
> Regards.
Sometimes I'm stupid: p.b.a. = povray-binary-animation. We often use
abreviations like this for the different sections of the newsgroups. Other
examples p.b.i. (povray binary Images) p.o.t. (povray off Topic) and so on.
