POV-Ray : Newsgroups : povray.animations : Feature request: EXIF for PNG Server Time
10 Jun 2026 16:30:18 EDT (-0400)
  Feature request: EXIF for PNG (Message 1 to 9 of 9)
Subject: Feature request: EXIF for PNG
Date: 25 Dec 2011 06:27:27
Message: <4ef7089f$1@news.povray.org>
At what clock did I produce my book cover?
I can not remember.
An EXIF information with the clock seting
in the PNG file would be very pracitcall.
Planetary Engineering Group Earth
Subject: Re: Feature request: EXIF for PNG
Date: 25 Dec 2011 12:35:02
Message: <web.4ef75e292cce60a660f285620@news.povray.org>
> I can not remember.
Doesn't your OS tell you when the file was created?
Date: 25 Dec 2011 13:41:19
Message: <4ef76e4f$1@news.povray.org>
On 2011-12-25 18:32, Roman Reiner wrote:
>> I can not remember.
Not the clock seting of the animation.
Date: 25 Dec 2011 13:58:49
Message: <4ef77269$1@news.povray.org>
But that is part of the filename...
     Thorsten
Date: 25 Dec 2011 16:14:28
Message: <4ef79234$1@news.povray.org>
Only for a full animation.
Not when I render single files
with higher resolution as it happened
at the book cover.
Date: 26 Dec 2011 12:41:58
Message: <4ef8b1e6@news.povray.org>
> I can not remember.
  Make a feature request at http://bugs.povray.org
  It sounds like something that would be useful and easy to implement.
Date: 27 Dec 2011 06:37:51
Message: <4ef9ae0f$1@news.povray.org>
On 2011-12-26 18:41, Warp wrote:
>> I can not remember.
Just registered as bugs.povray.org and sent the feature request
Date: 27 Dec 2011 12:40:01
Message: <web.4efa021c2cce60a658123d050@news.povray.org>
> >> I can not remember.
I think your feature request can be handled like this.
computer 1 should render 0..799
computer 2 should render 800..1599
In your animation.ini file:
Initial_Frame = 0
Final_Frame = 9999
Subset_Start_Frame = 0
Subset_End_Frame = 799
;Subset_Start_Frame = 800
;Subset_End_Frame = 1599
Only change your Subset_start/end_frames and not your Initial/Final_Frame.
This should give you four (4) digits on the resulting filename.
Stephen S
Date: 28 Dec 2011 03:42:52
Message: <4efad68c@news.povray.org>
>>>> I can not remember.
> Initial_Frame = 0
> Final_Frame = 9999
> Stephen S
Thanks!
Typical case from Read The Manual.
I did not scroll down far enough to read also the Subset setings.
