POV-Ray : Newsgroups : povray.animations : Animating Sombrero.png? Server Time
5 May 2024 10:23:40 EDT (-0400)
  Animating Sombrero.png? (Message 1 to 3 of 3)
Subject: Animating Sombrero.png?
Date: 9 Nov 2010 15:05:00
Message: <web.4cd9a8fbebc9549ab6bda1ce0@news.povray.org>
Hello, everyone,
I've been attempting to animate the Sombrero image that is included with PovRay,
but have failed so far...  Has anyone been able to do this, and how?
Thanks.
Subject: Re: Animating Sombrero.png?
Date: 9 Nov 2010 15:40:44
Message: <4cd9b1cc$1@news.povray.org>
On 09/11/2010 8:03 PM, DranoMax wrote:
> Hello, everyone,
> Thanks.
Sorry to say but that scene is not really made to be animated. Try
instead any of the scenes in \\scenes\animations\...
Ask away if you have any more questions.
Best Regards,
Date: 9 Nov 2010 19:39:00
Message: <4cd9e9a4@news.povray.org>
> Hello, everyone,
> Thanks.
It depends on how you want it animated.
Basicaly, it's a single frame static image with no provision for any
animation in the scene file.
You can rotate the shape. Add a rotate that depends on clock.
You can make the ossilations shift.
Original code:
#declare Zc = -1.0;
#while (Zc<=1.0)
   union
   // Xc goes from -1 to +1
   #declare Xc = -1.0;
   #while (Xc<=1.0)
     // precalculate height, since it is used several places below
     #declare YHeight = sin(sqrt(Xc*Xc+Zc*Zc)*6.28*2);
//change the preceding line to shift the function acording to the clock
variable.
     object
       BasicShape scale Increment
       translate <Xc, YHeight/4, Zc>
       texture
         // colors change across the object, and also go from black
         // in the valleys to full saturation at the peaks
         pigment { color rgb <Xc/2+1, 1-Zc/2, YHeight/2+1>*YHeight }
         finish { ambient 0.2 specular 0.5 roughness 0.05 reflection 0.2 }
     // manually increment our counter inside the loop
     #declare Xc=Xc+Increment;
   // manually increment our counters inside the loop
   #declare Zc=Zc+Increment;
Options follow:
#declare YHeight = sin(sqrt(pow(Xc*clock,2)+pow(Zc*clock,2))*6.28*2);
Shift with time
#declare YHeight = sin(sqrt(pow(Xc,2)+pow(Zc,2))*6.28*2*clock);
Raise with time
