POV-Ray : Newsgroups : povray.animations : Spheres stretching at the edges of the camera view--warping. Server Time
28 Apr 2024 18:35:19 EDT (-0400)
  Spheres stretching at the edges of the camera view--warping. (Message 1 to 8 of 8)
Subject: Spheres stretching at the edges of the camera view--warping.
Date: 15 Jun 2010 18:10:01
Message: <web.4c17f96077057e3ae1acfc5e0@news.povray.org>
I've been rendering some rolling spheres across the screen, but I'm noticing
that the spheres start to warp at the edges of my view. I've been playing with
the right function and other camera parameters, but I can't seem to get it
right.
This artifact appears almost like a stretching so the balls on the outside are
no longer perfectly spherical.
Has anyone seen this issue before? I'm thinking its something simple I'm not
doing.
Here's my camera and global setup:
_________________________________________________________
global_settings {ambient_light rgb< 1.5,1.5, 1.5>
  location  <0, 0, -12>
  direction 1.5*z
  up y
  right  x*image_width/image_height
  look_at   <0.0,0.0,0.0>
Here's one of my spheres:
 object { GolfBall
  scale 0.7
  rotate <0, 0, -clock*a*180>
  translate <-5.5, 2.9, 0>
  translate <1,0,0>
Is this possibly related to the scale of my objects/spheres?
Subject: Re: Spheres stretching at the edges of the camera view--warping.
Date: 15 Jun 2010 18:38:58
Message: <4c180102$1@news.povray.org>
RC wrote:
> Hi,
It's a projection effect. To reduce it, increase the distance
to the camera while decreasing the viewing angle.
Date: 16 Jun 2010 07:08:50
Message: <4c18b0c2$1@news.povray.org>
Am 16.06.2010 00:06, schrieb RC:
> Hi,
> right.
Well, the stretching /is/ right. You can't map the view of a 3d world,
as seen from a particular point, onto a 2d plane without distorting
/something/.
You would see the same effects in the real world with a pinhole camera,
which is the camera type after which POV-Ray's default camera is
modeled. Wide-angle lenses for cameras are sometimes(?) designed to
somewhat compensate for such effects, but at the cost of distorting the
image in some other way, e.g. distorting straight lines (fisheye lenses
are an extreme example of this).
That said, the ultra_wide_angle camera type might give you what you want.
To avoid any distortions at all, you'll need to move the camera as far
away from the scene as possible and reduce the camera angle (in that
case it's pretty irrelevant whether you choose the default camera or the
ultra_wide_angle camera - or go for the orthographic camera right away.
Date: 16 Jun 2010 12:12:51
Message: <4c18f803$1@news.povray.org>
> Hi,
> right.
> doing.
That's perfectly normal.
A sphere define a cone with it's apex at the camera location.
That cone intersects the view plane.
The intersection of a cone and a plane is an ellipse.
Thus, unless the sphere is at the very center of the image, giving a
perpendicular intersection, you get a more or less exentric ellipse.
Date: 17 Jun 2010 12:25:01
Message: <web.4c1a4be610c48c65e1acfc5e0@news.povray.org>
Alain <aze### [at] qwertyorg> wrote:
> > Hi,
> > right.
> > doing.
> Alain
Hi Alain,
Thanks you are right. After some calculating, all I have to do is render the
image larger by a desired amount, then crop the frames. Its just soooo slow to
render now, but I'm willing to wait it out to have the images correct.
THANK YOU!
Date: 18 Jun 2010 07:16:01
Message: <4c1b5571$1@news.povray.org>
Am 17.06.2010 18:23, schrieb RC:
Rendering a larger section of your scene doesn't change anything about
the stretching. What you'll need to do is move the camera backwards
instead. While this of course gives you a larger section of your scene
by default, too, you can compensate for this by using the "angle"
keyword. No need to crop with an external tool - and most of all no need
to wait for surplus parts of the screen to be rendered.
Date: 18 Jun 2010 10:05:02
Message: <web.4c1b7bf610c48c65ae3cb5160@news.povray.org>
.... evidence that if we don't need new camera syntax, we need new camera docs.
The docs don't lie to the person who wrote the code, but don't teach anything to
the newbie.
Date: 18 Jun 2010 16:45:00
Message: <web.4c1bda3610c48c65c59235590@news.povray.org>
Isn't this essentially Hitchcock's famous 'Vertigo Effect' (dolly zoom)?  It
would be neat to try and model this in a POV animation...
