POV-Ray : Newsgroups : povray.animations : is there a way to skip slow frames????? Server Time
19 May 2024 17:53:57 EDT (-0400)
  is there a way to skip slow frames????? (Message 1 to 4 of 4)
Subject: is there a way to skip slow frames?????
Date: 1 Feb 2010 11:15:00
Message: <web.4b66fd67eaa1d5e9824827c70@news.povray.org>
im using random landscapes in a modified version of terrapov but every once in a
while i get under the terrain or something and it renders black and
ssssssslllooooowwwww(slow).
i was wondering if there is a way for povray to skip to the next fram if certain
conditions are not met.
I know i can use trace but im not that skilled at it and "conditional skips"
would be more convenient!!
Subject: Re: is there a way to skip slow frames?????
Date: 1 Feb 2010 11:41:44
Message: <4b670447@news.povray.org>
  You can test if a point is inside a height_field using the inside() function.
You could use that to skip instantiating the heightfield or creating the rest
of the scene for that frame.
Date: 1 Feb 2010 21:16:15
Message: <4b678aef$1@news.povray.org>
If you detect that you are inside/under your terrain, you can move the
camera up by a few units, then test again.
If you are still inside, move up another step and do another test.
That way, you can make sure that your camera is over the terrain.
Date: 2 Feb 2010 12:40:26
Message: <4b68638a$1@news.povray.org>
I use to set the camera with the trace function to find the height of the terrain and
then add some value as offset in Y-direction.
Here's an example movie where I used this approach:
http://www.youtube.com/watch?v=20vMtS61n-Q
Joerg
