POV-Ray : Newsgroups : povray.animations : How to animate sub-region only Server Time
28 Jun 2024 21:36:45 EDT (-0400)
  How to animate sub-region only (Message 1 to 8 of 8)
Subject: How to animate sub-region only
Date: 22 Nov 2008 03:50:01
Message: <web.4927c762fb7773f43b34ecfe0@news.povray.org>
I have a scene where only a small part gets changed frame to frame so I want to
render the first frame fully and then the following frames only for a selection
of rows and columns, automatically keeping the rest of the pixel values
unchanged from first frame. How do I do this?
Subject: Re: How to animate sub-region only
Date: 22 Nov 2008 04:56:26
Message: <4927d74a@news.povray.org>
"sumdumguy" <nomail@nomail> wrote in message
news:web.4927c762fb7773f43b34ecfe0@news.povray.org...
>want to
> selection
I don't think there's a straightforward way of doing this. If your desire to
do this is to save render time you may well find you expend more time
developing a technique to glue all the bits together than you save when
rendering. However, if you're driven by some other motive then there are a
variety of approaches that spring to mind (all of which involve some
external post-processing).
You don't say whether each of the subsequent frames would be an identical
selection of rows and columns. If you want different rows and columns in
each frame then you'd need to invoke POV-Ray from the command-line (e.g from
a script) with different command-line options for each frame. Otherwise you
could use one POV-Ray render for the first frame and an animation sequence
(e.g. +kfi1 +kff100) to generate all the other frames.
There are partial animation command-line options, which may be of value to
you (see +sc in the help). If the rows and columns you want to render from
frame 2 are centred on the middle of frame 1, then you may find it easier to
adjust the width and height (+w +h) and compensate using the up and right
camera vectors (or the angle attribute), because then you don't have the
post-processing effort required to isolate the rendered sections from the
rest of the images.
Assembling the images into a single animation is always done outside of
POV-Ray using whichever tool serves you best. The technique you develop
would need to correspond with the capabilities of the utility you plan to
use and the format you wish to generate. For example, the GIF constructor
set (to build animated GIFs) allows you to retain a previous image and
overlay a new partial image at a particular location, so this would probably
lend itself to the technique of adjusting the width and height with the up
and right vectors.
Chris B.
Date: 22 Nov 2008 05:20:01
Message: <web.4927dbb3efcfba633b34ecfe0@news.povray.org>
> >want to
> > selection
> rest of the images.
> and right vectors.
> Regards,
> Chris B.
My goal is indeed to save time.
Here is why +sc option is no good for me. If I use +sc options, the resulting
image will have the pixels I want and black pixels elsewhere. So far so good.
But the location of the "good" pixels within the total image will be different
from where they are in the first frame.
Suppose I have a 1280x1024 image and I want to render row 2 through 5 and
columns 2 through 5. Just a tiny patch. This will render fine and produce a
mostly black image whose size is 1280x1024. But the non-black patch will not be
between columns 2 and 5 and rows 2 and 5. It will be starting at row 1 and it
seems to be centered columnwise. So I cannot just use software to map black
pixels to 100% transparency and then paste the new image on top of frame 1.
The real problem is that for large images with tons of isosurfaces and
anti-aliasing, the speed per frame is ~2 hours on my computer. If I can animate
1/1000th of the image that changes, I can save days (actually weeks) of
rendering.
Date: 22 Nov 2008 05:46:38
Message: <4927e30e$1@news.povray.org>
news:web.4927dbb3efcfba633b34ecfe0@news.povray.org...
>> >want to
>> > selection
>> to
>> rendering.
> resulting
> good.
> different
> a
> not be
> it
> black
> 1.
> animate
> rendering.
Sounds like you're on 3.6, which indeed does what you describe.
I'm using 3.7 Beta 27 on Windows at the moment and that seems to place the
pixels in the right place within the generated bmp image. It may be best and
quickest to try the 3.7 Beta for this (You can still keep a copy of 3.6
installed alongside it).
Chris B.
Date: 23 Nov 2008 12:32:51
Message: <492993c2@news.povray.org>
> a mostly black image whose size is 1280x1024. But the non-black patch will
> not be between columns 2 and 5 and rows 2 and 5. It will be starting at
> row 1 and it seems to be centered columnwise.
It doesn't always do that. It depends on the file format.
For PNG, it will start on row 1, and a special field inside the PNG format
will say where that row should really be located.
> software to map black pixels to 100% transparency and then paste the new
Use smarter software :) Put the rendered chunk in the correct place of the
frame 1 (you *know* what the correct place is, since you used it to tell
POV-Ray what to render).
If you map black pixels to transparency, wouldn't you have problems if the
rendered chunk has real black parts?
Date: 23 Nov 2008 16:05:00
Message: <web.4929c565efcfba633c7bd44e0@news.povray.org>
Depending on what changes and what else is in the scene, you could render the
static background, then render the animated part without anything else around
and use the alpha channel to composite.  You may also be able to achieve this
even if there is some degree of scene interaction (such as reflections or cast
shadows) by using the no_image, no_shadow, and no_reflection modifiers.
Of course, if a 'background' object occludes the animated object at some point,
it would need to be re-rendered with it and composited also.  Furthermore,
using radiosity in your scene will depend on the locations of all objects
present, which means that trying this technique with radiosity will not look
like it should.  There is also the issue of shadows cast by your object...
Some of the above issues can be worked around by clipping the entire scene into
a small box that moves with the moving object and having the background alpha'd
for compositing.  If you lengthen this box along the axis of the camera, toward
the camera, this could also ease occlusion problems.  It may take some work to
get such a thing going, you may still save some time.
-Reactor
Date: 23 Nov 2008 22:00:01
Message: <web.492a1787efcfba633b34ecfe0@news.povray.org>
> -Reactor
Yeah, I use radiosity and thing occlude each other. But holy jebus, 3.7 is so
fast. Thanks for that suggestion.
Date: 25 Nov 2008 09:39:29
Message: <492c0e21$1@news.povray.org>
I've done something like this; basically an image in a TV with a static
scene around it.
Easiest method I've found is to render the moving part as a separate
file, and then blue-screen/overlay/chromakey/... it into the final
animation using whatever video editing software you prefer.
Bryan
