POV-Ray : Newsgroups : povray.animations : Looking for Skin Deformation Utility that is Compatible with POV-Ray Server Time
20 May 2024 05:29:50 EDT (-0400)
  Looking for Skin Deformation Utility that is Compatible with POV-Ray (Message 1 to 2 of 2)
Subject: Looking for Skin Deformation Utility that is Compatible with POV-Ray
Date: 5 Mar 2008 23:35:00
Message: <web.47cf73706e7558949612e0670@news.povray.org>
Hello,
We are developing an automated skeleton animation system and are looking for a
rendering platform to display our results.  Our system currently outputs
control objects for a biped (we are basically creating an animated skeleton or
set of rigid control bones).  We have used 3DS-Max to convert our bone
animation into a final character animation.  We would like to render our output
using POV-Ray, but need to find a good solution for the skin deformations that
Max provides.
For example, in Max, we can create a NURBS point surface model for the skin and
apply a skin deformation controller to the NURBS control points.  The skin
controller is driven by the position of our bones objects, and the result is a
very nice smooth animated biped.  The skin deformation controller lets us
easily specify the bone influence over the NURBS control points.
We are looking for the following:
1) A skin deformation utility that can deform a NURBS model using a set of
control bones as input and produce POV-Ray compatible output (using Bezier
Patches).  We would supply the bone transformations for each frame.  We would
like to be able to edit the control influence of each bone on the various NURBS
control points.
2) A good NURBS modeler that would be compatible with the above.
We would run this utility for each frame.  We have also considered using
polygon-meshes for the skin.
Any ideas or links to existing utilities would be greatly appreciated.  Links to
good papers on the subject would also be a great help.  Thanks!
Subject: Re: Looking for Skin Deformation Utility that is Compatible with POV-Ray
Date: 29 May 2008 07:57:17
Message: <483e9a1d@news.povray.org>
"Dave" <nomail@nomail> wrote in message
news:web.47cf73706e7558949612e0670@news.povray.org...
> Hello,
> for a
> skeleton or
> output
> that
> Max provides.
Hi Dave,
I've not seen anything that does precisely this, and, judging by the lack of
responses to your posting it doesn't seem like anyone else has either. There
are utilities such as PoseRay that convert other formats into POV-Ray mesh
or mesh2 objects.
> would
> NURBS
> control points.
I've seen a couple of examples of skin deformation done in POV-Ray and have
done some myself, but I don't recall seeing any published source code. The
POV-Ray macros I wrote manipulate skin surface points that are stored in a
POV-Ray array, applying deformations based upon joint rotations. I've then
got further macros to generate mesh objects from the arrays. The deformation
macros that I wrote are different for each type of joint. I only got as far
as doing the eye lids and the finger joints.
If you already have skin shapes for each frame in a format that PoseRay can
handle, then it sounds like problem solved? I think that most human
animation in POV-Ray is handled this way with a frame by frame export from a
human modelling application.
> Links to good papers on the subject would also be a great help.
> Thanks!
Material related to doing human animation in POV-Ray is currently pretty
light on the ground. I like to think that the most mature attempt was my
POV-Person library at http://www.geocities.com/povperson/.
Before that, the only humanoid I'm aware of done solely in POV-Ray was a
very old thing called Blobman. Terresa Willis did a walking animation many
moons ago, but that was of a solid robotic form. A couple of old hands have
incorporated Poser models and I recall seeing a decent walking animation
done using Poser a long time ago.
There was an impressive muscle deformation animation a couple of years back
on the povray.binaries.animations newsgroup, but it only did the arm
muscles. I've done a few macros since POV-Person to do the finger and eyelid
deformations I mentioned above and one to do dynamic hair.
Maybe this posting will prompt people to remember other stuff that could be
relevant.
Regards
Chris B.
