POV-Ray : Newsgroups : povray.animations : Polygonal Animation Software Server Time
12 Jul 2025 17:16:09 EDT (-0400)
   Polygonal Animation Software (Message 1 to 2 of 2)
Subject: Polygonal Animation Software
Date: 25 Jun 2007 10:50:02
Message: <web.467fd4e9fab32d10a606a85b0@news.povray.org>
I hope this is not a dumb question.
Is there a way to run a PovRay file through a program and have an animation
that is created by polygons.
This I believe would be like using some sort of games style rendering
engine.
Would I be able to see the complete animation in a shorter amount time?
Thanks.
Subject: Re: Polygonal Animation Software
Date: 29 Jun 2007 17:17:32
Message: <468576ec$1@news.povray.org>
"krnl Jnz" <nomail@nomail> wrote in message
news:web.467fd4e9fab32d10a606a85b0@news.povray.org...
> animation
> engine.
> Thanks.
It's a little hard from this description to tell exactly what you'd like to
do, but I'm guessing you'd like to convert objects from a POV-Ray scene file
into a format that could be rendered by another piece of software. Then I'm
guessing you're wanting to use the other software to do something like a
fly-through, or some form of real-time navigation through the scene.
I don't think you'll find a converter that would easily do that for you, but
there are some things that you might want to consider instead:
There is an experimental real-time ray-tracing feature in Beta 17 of POV-Ray
see http://www.povray.org/beta/rtr/.
Alternatively VRML lets you fly-through scenes in real time (using a VRML
viewer). Other 3D formats also support quicker rendering that could give you
quicker animations or real-time rendering. So far as I'm aware there's no
automatic way of converting from POV-Ray format to a polygon based format,
but there are a number of things in POV-Ray that can help.
You can use the trace function to 'scan' an object and you can write out the
coordinates of the points and the surface normals into a file.
There are various functions available that can convert an array of points
and normals into a mesh object which you may be able to canabalise to create
a format that is closer to the format required by another 3D format. e.g.
VRML format.
Chris B.
