POV-Ray : Newsgroups : povray.animations : Animating light pulses following curved paths in an Optical CPU Server Time
13 Jul 2025 00:18:49 EDT (-0400)
  Animating light pulses following curved paths in an Optical CPU (Message 1 to 7 of 7)
Subject: Animating light pulses following curved paths in an Optical CPU
Date: 10 Dec 2006 20:05:00
Message: <web.457cad8ac5c6b6f49626fb630@news.povray.org>
Hi all,
I wish to make an animation of light pulses moving around an optical CPU.
The geometry consists of multiple curved paths, and looks something like
this (although the final version will be much more complicated):
http://guidetomp3players.com/images/heightfield2.png
The geometry is based on a 2D image essentially drawn by hand, and the
constituent curves are not defined mathematically so I can't easily
parameterize the paths. So what I think I need is a tool where I can trace
the geometry by hand and get as output paths that I could import into
POV-Ray for the light pulses to follow. Does anyone know of a tool/utility
that could do this?
Of course if someone can think of a better way to do it then I'd love to
hear your thoughts.
Cheers.
Subject: Re: Animating light pulses following curved paths in an Optical CPU
Date: 11 Dec 2006 03:35:01
Message: <web.457d182c68cfae07f1cb1e660@news.povray.org>
"scam" <sca### [at] mailusydeduau> wrote:
> Hi all,
> hear your thoughts.
> Cheers.
Just a thought, the trace function looks as if it is made for the job.
3.2.1.4.5  Functions
Date: 11 Dec 2006 04:06:54
Message: <457d1fae$1@news.povray.org>
"scam" <sca### [at] mailusydeduau> wrote in message
news:web.457cad8ac5c6b6f49626fb630@news.povray.org...
> Hi all,
> that could do this?
> hear your thoughts.
> Cheers.
You may care to look at InkScape, which is a free 2D SVG editor which can
output vector graphics based shapes as POV-Ray prism obect definitions. The
prism objects contain bezier_splines that you could use in POV-Ray to track
along the curves. You'd need to extract the splines and wrap it in
appropriate SDL for declaring the splines. If the shapes get complicated
you'd probably want to write a script to do that.
Chris B.
Date: 11 Dec 2006 07:15:01
Message: <web.457d4b4468cfae0719862de70@news.povray.org>
"Chris B" <c_b### [at] btconnectcomnospam> wrote:
> Hi,
> Regards,
> Chris B.
That looks like it will work perfectly, thanks for the great tip! I can move
the entire project from Illustrator to InkScape, and do the two hardest
steps in one hit. Cheers mate.
Date: 18 Aug 2007 06:15:00
Message: <web.46c6c5f468cfae07b0f5bef80@news.povray.org>
just tried on inkscape 0.45, there is now a option to save as .pov
8)
> > Hi,
> > Regards,
> > Chris B.
Date: 30 Sep 2007 11:06:18
Message: <46ffbb6a$1@news.povray.org>
It can?! I have had Inkscape for long and I never saw such option! I
might have an old version... *upgrades*
Date: 30 Sep 2007 11:19:00
Message: <46ffbe64@news.povray.org>
"Nicolas Alvarez" <nic### [at] gmailisthebestcom> wrote in message
news:46ffbb6a$1@news.povray.org...
>> The prism objects contain bezier_splines ...
> It can?! I have had Inkscape for long and I never saw such option! I might
I have 0.43 from Nov 2005.
With that you just choose 'Save As' and select the format POVRay
(*.pov)(export splines).
Chris B.
