POV-Ray : Newsgroups : povray.animations : animation of two object Server Time
27 Sep 2024 18:17:30 EDT (-0400)
  animation of two object (Message 1 to 4 of 4)
Subject: animation of two object
Date: 15 Mar 2005 09:25:00
Message: <web.4236ef8b42bd04a9fe7107b80@news.povray.org>
I want to make a mouvement of 2 objects different. And the camera look at
the center point in this mouvement. In this case, my 2 object is the cone
and the difference(cylinder and quadric). How I can make this? I hope you
understand my question!!! Thanks a lots
camera{
        location  < 0 , -2 , 0.0 >
        look_at   < 0 , 1.0 , 0.0 >
difference{
        cylinder{
                 < 0, -0.4, 0 > , < 0, 2.5, 0 >, 4
        quadric{
                < -1 , 1 , -1 >         //  A x^2  + B y^2  +  Cz^2
                < 0 , 0 , 0 >           //  D xy   + E xz   + F yz   +
                < 0 , 2.83 , 0 >        //  G x    + H y    + I z    +
                1                       //  J
        texture {Mirror}
        translate <2,0,0>}
cone{
    <0,-1.5,0>,0,<0,-0.4,0>,0.2
    pigment {Black}
    translate <2,0 ,0>
Subject: Re: animation of two object
Date: 15 Mar 2005 09:35:07
Message: <4236f29b@news.povray.org>
  Just calculate the positions of the two objects using 'clock'?
Something along the lines of:
#declare Object1Position = <clock*10, 0, 0>;
#declare Object2Position = <-clock*5, 0, 0>;
camera { location <0,-2,0> look_at (Object1Position+Object2Position)/2 }
difference
{ whatever
  translate Object1Position
cone
{ whatever
  translate Object2Position
Date: 15 Mar 2005 11:56:57
Message: <OWRAKFAOOxNCFwKg@econym.demon.co.uk>
>camera{
>difference{
>        cylinder{
>        quadric{
>                1                       //  J
>        texture {Mirror}
>        translate <2,0,0>}
>cone{
>    pigment {Black}
>    translate <2,0 ,0>
I'd suggest declaring the whole thing as a single union. The centre of
that pair of objects is approximately the centre of the bounding slab of
the union.
#declare THING = union {
  difference { ...
  cone {...
#declare CENTRE = (min_extent(THING)+max_extent(THING)) / 2;
  look_at CENTRE
Alternatively you could calculate the centres of the two parts in a
similar way and take the average of those two values.
Mike Williams
Gentleman of Leisure
Date: 16 Mar 2005 03:40:00
Message: <web.4237efb127ac8165fe7107b80@news.povray.org>
Thanks. I will test your suggest.
