POV-Ray : Newsgroups : povray.animations : Radiosity Server Time
26 Jun 2024 14:44:01 EDT (-0400)
  Radiosity (Message 1 to 8 of 8)
Subject: Radiosity
Date: 1 Mar 2005 08:48:01
Message: <42247291$1@news.povray.org>
I've never been able to animate in scenes with Radiosity because the
lighting differs from one frame to the next.  I've tried all of the usual
things of upping the various quality values but the flicker never leaves.
Is it best to just keep radiosity out of Anims?
Subject: Re: Radiosity
Date: 1 Mar 2005 09:49:30
Message: <Xns960CA0FB646B4jgrimbertmeandmyself@203.29.75.35>
> usual things of upping the various quality values but the flicker
> never leaves.
This is 'by-design'...
Yes.
At best, you can try photons...
This is an unauthorised cybernetic announcement.
When someone says "I want a programming language in which I need only
say what I wish done," give him a lollipop.
Date: 2 Mar 2005 05:50:24
Message: <42259a70@news.povray.org>
No. Have you tried to save the radiosity data and then reusing them
instead of calculating them for each frame?
Just my 2 eurocents,
Bonsai
    ___ __ __  _ ___ ___  _
   | _ )  \  \( )  _) _ )( )
   | _ \() |\ \ |\ \/ _ \| |
   |___/__/_)\__)___)/ \_)_)
        www.b0n541.net
Date: 10 Mar 2005 02:17:07
Message: <422ff473$1@news.povray.org>
I'm creating a walkthrough by animating my camera.  I'm using the
ClockModifier includes
http://www.geocities.com/SiliconValley/Lakes/1434/clockmod.html
and adding these lines to my povray.ini file
Initial_Frame = 1
Final_Frame   = 250
I know how to save my radiosity solution with
save_file "file_name"
but then how is this reloaded for each subsequent image rendered?
TIA
Russ
Date: 10 Mar 2005 05:05:29
Message: <42301be9@news.povray.org>
Make some still shots from every place in your walkthrough. Save the
radiosity data of all these shots and copy them all into one file. Now
you can use this file for evey frame. POVRay will select the right data.
Hope that helps.
So long,
Bonsai
        www.b0n541.net
Date: 10 Mar 2005 05:22:36
Message: <42301fec$1@news.povray.org>
Or: render the animation and save the radiosity from every frame, or every
few frames (depending on the speed your camera is moving, and how the
scenery changes), and stitch all that together for a second render pass...
Might be easier than figuring where to best place the camera to collect the
required radiosity data.
"Tim Nikias v2.0"
Date: 10 Mar 2005 11:58:46
Message: <42307cc6$1@news.povray.org>
If the scene isn't changing at all, then saving and loading radiosity data
is exactly what you want. The parts of the scene which were visible in the
previous frame will already have their radiosity set up, and the parts which
are newly visible will have their radiosity calculated. This avoids a lot of
recalculation, and areas that were visible in the last frame should be left
mostly unchanged.
#if (frame_number > 0)
load_file "filename"
save_file "filename"
I guess I should say that I've never tried this method, but in theory it
should work.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 23 Nov 2005 11:00:00
Message: <web.438491b04485a72b0d78f980@news.povray.org>
to bad there isn't a "save_file 'file2' append"
