POV-Ray : Newsgroups : povray.animations : lame png -> avi Server Time
27 Sep 2024 18:38:31 EDT (-0400)
  lame png -> avi (Message 1 to 6 of 6)
Subject: lame png -> avi
Date: 5 Dec 2004 13:02:56
Message: <Xns95B6C20D17293raf256com@203.29.75.35>
sorry for such easy question, but Im realy in a hurry,
how can I compress *.png / *.tga output into *.avi in XVid/DivX/Mpeg-1,2,4
codecs, and set up quality (and kb/s, and use 2-pass encoding)?
Can this be done in MPlayer (how?)
http://www.raf256.com/3d/
Computer Graphics
Subject: Re: lame png -> avi
Date: 5 Dec 2004 14:05:00
Message: <web.41b35b6cf0f9442570da6b7c0@news.povray.org>
Hi
I render the frames of animation in *.bmp, then i use avicreator to make an
avi and then convert to mpeg1 with TMPGEnc. I finally got a "configuration"
for a good quality mpegs but i think i still have to find optimal one.
If u want i send you the .mcf file for configuration on TMPGEnc.
Was this what u were asking for ? :P
See ya.
                   Manuel Mata Rueda
                   http://es.geocities.com/manuel_mata_rueda
Date: 5 Dec 2004 14:32:57
Message: <Xns95B6D150367DDraf256com@203.29.75.35>
man### [at] yahooes
news:web.41b35b6cf0f9442570da6b7c0@news.povray.org
Ufm.. yes ;) But - I need this on Linux (and best - from command line :)
Computer Graphics
Date: 6 Dec 2004 02:28:22
Message: <41b40a16@news.povray.org>
  Then use mencode. It can read image files directly and create an avi
with whichever encoding you like.
Date: 9 Dec 2004 18:05:00
Message: <web.41b8d934f0f94425160cebe80@news.povray.org>
I run Linux,.... Kjpeg2Avi is what I use. You can use it either from the
command line or with the KDE GUI. You should find it at Sourcefourge
repository or do a search.
Even though it says it converts jpeg to avi, it manages to convert png to
jpg then to avi. Of course, you need to make sure the frame size is correct
for avi.
hope this helps?
TOM
Date: 16 Aug 2005 13:55:00
Message: <web.430227e8f0f9442544365ed70@news.povray.org>
"Rafal 'Raf256' Maj" <spa### [at] raf256com> wrote:
> Hi,
Read the MPlayer/MEncoder man page.
mencoder "mf://*.png" -mf fps=30:type=png -o output.avi -ovc lavc -lavcopts
vcodec=msmpeg4
Feel free to change "*.png" to "name???.png" and "output.avi" to whatever
you want.
Feelfree to change msmpeg4 to whatever you want that is supported; see "lavc
(-lavcopts)" under the man page of mplayer.
Man page can be accessed via "man mplayer" or online on a mirror that isn't
the main one (which is currently offline).
