POV-Ray : Newsgroups : povray.animations : problems with motionblur Server Time
8 Jul 2024 18:44:54 EDT (-0400)
  problems with motionblur (Message 1 to 5 of 5)
Subject: problems with motionblur
Date: 1 May 2003 04:19:47
Message: <3eb0d8a3@news.povray.org>
Hi all,
i have some problems using "average.exe", wich means, i can't get it to
work. When i type <average wiebel[00-30].tga wiebel[1].tga>, the progam
gives an error, and quits. I don't know how to solve this.
Any help is welcome,
JWV
Subject: Re: problems with motionblur
Date: 1 May 2003 17:34:35
Message: <3eb192eb@news.povray.org>
  Quoting the error message in question would help, as well as telling
your operating system and other relevant details.
  By the way, did you try putting the parameters into quotation marks,
like this:
average "wiebel[00-30].tga" "wiebel[1].tga"
Date: 2 May 2003 07:33:26
Message: <3eb25786$1@news.povray.org>
I use win98SE, on a Celeron 500. The images were converted from .bmp to TGA
by PaintShopPro 7. The resolution of the images is 512x384, 24 bits
uncompressed TGA.
a screen dump with the error can be seen at:
http://home.planet.nl/~vaand013/screen.jpg [49 KB]
As you can see, the error wich i was refering to, is only shown when it
should work.
JWV
news:3eb192eb@news.povray.org...
> like this:
Date: 2 May 2003 12:29:06
Message: <3eb29cd2@news.povray.org>
> should work.
  It's not an error message from the program. The program simply crashes.
Which of course means it's buggy.
  I could look at the problem if I can find the source... It has been so
long since I made the program.
Date: 4 May 2003 14:13:40
Message: <3eb55854$1@news.povray.org>
I think you made the source available for download with the program =)
 - Slime
[ http://www.slimeland.com/ ]
