POV-Ray : Newsgroups : povray.animations : 2d-text as 'floating label' Server Time
6 Oct 2024 12:18:48 EDT (-0400)
  2d-text as 'floating label' (Message 1 to 2 of 2)
Subject: 2d-text as 'floating label'
Date: 19 May 2002 19:08:02
Message: <3ce83052$1@news.povray.org>
Does anyone know how it is possible to overlay a 2d-text 'label' over a
selected object so that it may float, sticked to its object's trajectory,
without changing itself in size and orientation (always horiz)?
That is, a kind of "floating label" for a rendered object.
Thanks.
Subject: Re: 2d-text as 'floating label'
Date: 22 May 2002 05:46:55
Message: <3CEB692E.4060704@free.fr>
I do not know, but :
  - using an orthographic camera
  - a text object with no_shadow & no_reflection, ambient set to 1, and
diffuse to 0, scale & rotate & translate set to your will,
you could place a text anywhere on the picture.
First make it with a fixed camera, with the sky & up set to size*y,
direction k*z and right ratio*size*x.
Then try moving the camera with some translate & rotate.
Applying the same transformation to the text should make it follow in
the picture.
Avoid Look_at !
Non Sine Numine
http://grimbert.cjb.net/
Puis, s'il advient d'un peu triompher, par hasard,
