![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I am working on an animation where one large plane is flying through the
air.
I would like to add some realistic clouds and ... thunder. Any ideas how
this can be done? The thunder does not have te be visible directly. Just the
illumination on the clouds. (I saw this in the movie 7 days, 7 nights).
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"jansb000" <jan### [at] wxs nl> wrote in message
news:3b1b5d2d$1@news.povray.org...
the
Easy enough. Well, easy if you know media.
Place several light sources in and around the media clouds and set them to
flash randomly.
// WhereCloudsAre would be the confines of media container or therein.
#declare LightningPlace=rand(seed(123*clock))*WhereCloudsAre;
#declare Flash=rand(seed(321*clock));
#if (Flash<.5) #declare Flash=0; #end // limiter
light_source {LightningPlace,Flash}
There are some fine examples of media clouds in the newsgroups here,
povray.binaries.scene-files or the p.t.s-f.
You did ask for realism so media is about it for that. Then again you might
be able to use the textured layered plane or sphere method.
Bob H.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In article <3b1b5d2d$1@news.povray.org>, "jansb000" <jan### [at] wxs nl>
I assume you mean lightning...just put a bright light source in the
clouds when you want a flash of lightning (assuming you are using media
clouds). A one-frame flash might be enough, or you may want groups of
flashes over a period of time, which would be a bit more involved but
not difficult.
Christopher James Huff - chr### [at] mac com, http://homepage.mac.com/chrishuff/
TAG: chr### [at] tag povray org, http://tag.povray.org/
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
If I was you, I would work on a good bozo map with turbulence for the
clouds, then make one of the value change from whatever to bluewish / white
randomly, for wuick period of time.
"Chris Huff" <chr### [at] mac com> wrote in message
news:chr### [at] povray org...
the
> not difficult.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
