POV-Ray : Newsgroups : povray.animations : Advice for animation entry? Server Time
28 Jul 2024 12:27:51 EDT (-0400)
  Advice for animation entry? (Message 1 to 3 of 3)
Subject: Advice for animation entry?
Date: 3 Jan 2001 17:54:40
Message: <3A53ADE5.F07BB573@spiritone.com>
I am close to finalizing my IRTC animation entry for this round and I
have a few questions about getting a decent quality on the animation
when I encode it.
I am planning on a 320 by 240 image size, so should I render at that
size or render at a larger size and let the MPEG encoder shrink it?
How often should I set a keyframe? If I am using 24 frames per second
and each camera shot is set up in nearly even second intervals, should I
have a key frame every 12 or 24 frames?
I will be doing the rendering on an iMac, but I have virtual PC so I can
use DOS and Windows based compilers.
Thanks for any help anyone has.
eng### [at] spiritonecom
Subject: Re: Advice for animation entry?
Date: 4 Jan 2001 03:39:45
Message: <3A54371A.D11B3E5D@atosorigin.com>
> when I encode it.
Only 11 days lefts... I hope your files render very quickly.
povray is usually better with AA than oversized shrink,
so I would render at the final image size, but you may want to
try it...
Who care... key frames are usefull for fast forward/backward and reducing
the blurry introduced by prediction.
My hint: renders all your frame (that's the longuest part),
then try both setting and see which one is better
 (more key frames usually increase the file size, so beware of
the 5 Meg limits).
Date: 4 Jan 2001 15:41:53
Message: <3A54E04F.1C502AC6@spiritone.com>
> > when I encode it.
> try it...
It's taking about 1 hour to render 14 seconds of animation at 24 fps... my
animation is not full of great scenery, I'll be the first to admit that.
> the 5 Meg limits).
Thanks, I have enough time to get the rendering done, I'm worried about the
experimentation time to get the MPEG looking good, not blurry, and under the
file size...
Josh
