POV-Ray : Newsgroups : povray.animations : Passing variables between iterations Server Time
28 Jul 2024 14:22:10 EDT (-0400)
  Passing variables between iterations (Message 1 to 7 of 7)
Subject: Passing variables between iterations
Date: 7 Sep 2000 16:29:42
Message: <39b7fab6@news.povray.org>
How can I pass a variable between frames rendering iterations in POV?
I'm running an 1800 frame animation, 30 frames per second, and I want a
different random number every 6 seconds (180 frames).
I created an array of 10 random numbers, and then used the clock to select
the number from the array. This works, but is sloppy and not truely random!
Is there a way to pass a value from one frame to the next?
Richard Brooks                 email: bro### [at] kmrmailkmrllmitedu
Work: (805)355-6583        Home: (805)355-6734
Range Systems Engineering (RAYTHEON)
Field Engineer, Commodore, Roi-Namur Yacht Club,
President & General Manager, Roi-Namur Television,
and just all arround nice guy!
Kiernan Re-Entry Measurements Site  Kwajalein Atoll
Roi-Namur, Marshall Islands
E 167 28' Long., N 9 23' Lat.
Subject: Re: Passing variables between iterations
Date: 7 Sep 2000 17:36:50
Message: <39b80a72$1@news.povray.org>
In article <39b7fab6@news.povray.org> , "Richard Brooks"
Using the file IO functions you can write them to a file and read them in
the next time.   The file IO functions are explained in the manual.
     Thorsten
e-mail: tho### [at] trfde
Date: 7 Sep 2000 23:37:01
Message: <39B85E79.89A9E67C@student.murdoch.edu.au>
You can use persistent variables in MegaPOV (
http://nathan.kopp.com/patched.htm ) but as far as I know they don't work
properly in the current version (0.5a)
- 0.5 worked though if you want it (I have it at home)
or you could try MegaPOVPlus cur ver 0.5a mod 0.3. (I don't know if it works)
Bye
Pabs
Date: 8 Sep 2000 07:34:08
Message: <39B8CEB0.477C4A6B@erols.com>
> a different random number every 6 seconds (180 frames).
// these two lines are to eliminate a potential FP rounding error
#declare Frame=floor(clock*30+.5); // 30 comes from the frame rate
#declare Clock=Frame/30;
#declare Seed=seed(floor(Clock/6));
#declare MyRandomValue=rand(Seed);
MyRandomValue will change every six seconds.
Hope this helps,
John
Date: 8 Sep 2000 07:35:58
Message: <39b8cf1e@news.povray.org>
"Richard Brooks" <bro### [at] kmrllmitedu> wrote in message
news:39b7fab6@news.povray.org...
random!
If the values where generated with rand(seed), can't re-generate them for
each frame?
Something like (from the top of my head and utterly untested) :
#declare aSeed=123;
#declare currentFrame=clock*1799;
#declare iterator=0;
#while (iterator=<currentFrame)
  #declare randomNumber=rand(aSeed);
  #declare iterator=iterator+180;
Povingly,
Philippe
Date: 8 Sep 2000 07:49:45
Message: <39b8d258@news.povray.org>
Philippe Debar <phi### [at] hotmailcom> wrote:
: #declare aSeed=123;
:   #declare randomNumber=rand(aSeed);
  I don't think this will work.
Date: 8 Sep 2000 08:12:01
Message: <39b8d791@news.povray.org>
news:39b8d258@news.povray.org...
ooops
#declare aSeed=seed(123);
