POV-Ray : Newsgroups : povray.animations : asteroid mpg Server Time
28 Jul 2024 16:25:45 EDT (-0400)
  asteroid mpg (Message 1 to 4 of 4)
Subject: asteroid mpg
Date: 26 Dec 1999 17:48:28
Message: <38669ACA.D4276F01@rcia.com>
Exploder include from Chris Colefax used for my (mpg) asteroid impact
which is posted on his site was done sometime ago, i have never recieved
any feedback as
there is no email or web site linked back to me (www.rcia.com/lsalme)
http://www.rcia.com/lsalme/index.htm
I have'nt had much time to use the newest version of Pov but was
confused about the (;) requirement errors when i tried
using Spliner include, parsing seemed to loop on and on. Any tips
Subject: Re: asteroid mpg
Date: 26 Dec 1999 21:56:23
Message: <3866d557@news.povray.org>
Use the -GW command-line switch (or Warning_Console=Off in your Ini file) to
turn off the warning about semicolons being needed, since they don't
actually cause a real problem.
"Laurence M. Salme" <lsa### [at] rciacom> wrote in message
news:38669ACA.D4276F01@rcia.com...
> any feedback as
Date: 26 Dec 1999 22:08:21
Message: <3866D92E.48B50798@pacbell.net>
> Bob
The real fix for this is to place a semi-colon after each declare in
the include file or even better download a new version of the include
file from Chris's site. He has updated all of his include files to be
compatible with the POV-Ray v3.1 syntax.
Examples of where the semi-colon is needed -
#declare Vector = <1,3,5>;
#declare Float = 12;
#declare RGB = rgb<1,0,.34>;
#declare RAND = seed(1234);
Wishing you Seasons Greetings and A Happy New Millennium !
Date: 27 Dec 1999 18:22:44
Message: <3867f4c4@news.povray.org>
> any feedback as
There is an email link with the animation on my page - perhaps it is the
wrong address?
As for the problem with the Spline include file - this is simply because it
was designed for POV-Ray 3.0, which did not require semi-colons after
declarations of floats and vectors.  This also means that it is inefficient
by the standards of POV-Ray 3.1 (it uses neither macros nor arrays), and
desperately in need of an update.
The good news is that the updated file itself has been finished for quite
some time, and I am currently working on examples and documentation so
others can make sense of it!  These newsgroups will be notified when the
file is released.
In the meantime, you can use the existing Spline include file by following
the instructions on my page (under Other includes), or perhaps you could
look at using one of the custom versions of POV-Ray that support splines.
