POV-Ray : Newsgroups : povray.animations : Povray animation Server Time
28 Jul 2024 16:31:19 EDT (-0400)
  Povray animation (Message 1 to 4 of 4)
Subject: Povray animation
Date: 29 Oct 1999 07:25:23
Message: <3819849D.E37114D2@cybercable.fr>
I have objects (generated by a molecule viewer) only in .pov format. I
would like to make flight paths for the camera.
The "animsystem" is not compatible with povray 3.1 (semicolomn
problems),
Has anybody  an idea to simply create an animation ?
Thanks
Charles
Subject: Re: Povray animation
Date: 29 Oct 1999 08:35:33
Message: <381993B8.DA9CB213@pacbell.net>
> problems),
If you find it easy to use the "animsystem" don't let Pov's warnings about
the semi colon worry you. Those warnings only indicate that you should have
a semi colon but they are not absolutely necessary and will not make your
scene look any different.
Ken Tyler -  1100+ Povray, Graphics, 3D Rendering, and Raytracing Links:
Date: 29 Oct 1999 08:53:11
Message: <3819992E.572F95AC@cybercable.fr>
Thanks ken to answer so quickly
So if you have good ideas for animations. You know probably my problem:
I want to make flight path inside molecules  (from pdb format but displayed
options ie solid structures and colors made with MSI WebLab viewer) that I
have only in .pov format.
Charles
> > problems),
Date: 7 Nov 1999 00:56:14
Message: <3825154E.27B3@the-spa.com>
Just to add another possibility for you in terms of camera flights...
Chris Colefax has a great Include File / Macro for doing animations
called the Automatic Clock Modifier. Using that with Chris's spline
generator lets you create a complex path that the camera can follow...
for more info. look at this tutorial:
http://www.puzzlecraft.com/cm/ClockMod.html
Shawn =)
sha### [at] the-spacom
http://www.the-spa.com/shawn.fumo/
