POV-Ray : Newsgroups : povray.animations : wireframe from POVRAY? Server Time
12 Nov 2024 19:49:08 EST (-0500)
  wireframe from POVRAY? (Message 1 to 8 of 8)
Subject: wireframe from POVRAY?
Date: 10 Oct 1999 23:42:09
Message: <38015c91@news.povray.org>
Can POVRAY generate wire frame images? Or is there a patch or tool to help
it do so?
Linh.
Subject: Re: wireframe from POVRAY?
Date: 11 Oct 1999 02:02:57
Message: <38017D87.5C99DFE7@pacbell.net>
POV-Ray has not internal ability to do this.
> it do so?
If you have an object made in a different program like 3ds or dxf the
program 3DWIn has a pov wireframe export option that uses blobs to
create a wire frame of the object. The file size can become very large
and it 3DWin cannot read pov files. You can find 3DWin on my links page.
Ken Tyler -  1100+ Povray, Graphics, 3D Rendering, and Raytracing Links:
Date: 11 Oct 1999 04:58:44
Message: <3801A6C1.45585E9@uni-paderborn.de>
> > it do so?
i remember a povray tool which makes bounding
boxes visible. this is not exactly what the
question was about - but should it help, i'm
sure ken has a link in his repository...
	y.
Date: 11 Oct 1999 16:44:42
Message: <x0sCOLh1jAVRoKXYxZfRJ9DtYKB2@4ax.com>
>it do so?
  Linh, if you are on the Windows platform the Moray modeler can use the
Polyray plug-in by Alexander Enzmann, which can output wireframe images. I
have only tried it with shape primitives, not blobs or meshes.
Alan
Date: 11 Oct 1999 16:46:53
Message: <38024C83.586A29E8@pacbell.net>
>         y.
I think the correct link for this would be the POV-Ray documentation.
There is a switch that will let you render the bounding boxes visible
but I don't know what it is off hand.
Date: 12 Oct 1999 00:07:18
Message: <8bMCOBwNshlj5OL=pQjOBgTs4bHJ@4ax.com>
  Ken, +ud will display bounding boxes using a 2D representation.
Interestingly, I had to turn off the focal blur in the test scene I happened
to be using before I could see the bounding boxes.
Alan
Date: 12 Oct 1999 03:10:48
Message: <7twCOC+z5WEPpXlam4M2OZmXHO61@4ax.com>
>it do so?
>Linh.
The macro "Striscia" can be used to simulate a wire frame and the originator, Daniele
Varrazzo, gives an example of this in his documentation. It's only good for swept
surfaces
though. Striscia is at:
http://members.xoom.com/dvarrazzo/epov.htm
David
dav### [at] cwcomnet
http://www.hamiltonite.mcmail.com
Date: 12 Oct 1999 05:05:50
Message: <3802F9EA.9CD1237A@uni-paderborn.de>
> >         y.
:) this is what i meant. yes, some tools are
comprised in povray. (look in the book, y.!)
	y.
