POV-Ray : Newsgroups : povray.animations : Creating a Flash Appearance Server Time
28 Jul 2024 18:19:19 EDT (-0400)
  Creating a Flash Appearance (Message 1 to 2 of 2)
Subject: Creating a Flash Appearance
Date: 5 Sep 1999 17:13:24
Message: <37d2dcf4@news.povray.org>
Does someone have any experience in creating a Flash to cover the appearance
of a new Object? Something looking like appearance of Q in Star Trek - Next
Generation? I tried some interior effects, but the results are not quite
satisfying.
thanks in advance
GB
Subject: Re: Creating a Flash Appearance
Date: 5 Sep 1999 21:14:15
Message: <37d31567@news.povray.org>
Possibly a centrally opaque lens flare would be okay.  Simply use
either the Nathan Kopp or Chris Colefax *.Inc and set the
filter/transmit part to vary as you want.  Of course this means making
changes to the scripts perhaps but probably just to add a new custom
flare.  Reason this would be good is that the flares are camera-based
and can be oriented to overlay an object in your scene.  If your
wanting a object shape defined "flash" I could only suggest rendering
the object alone scaled upward some (centering important) with a
single flat texture (+q0 command line option might do) and then
overlay that as a filtered 'image_map' over a normally rendered
image_map of your scene.
GBR <nir### [at] nospamcom> wrote in message
news:37d2dcf4@news.povray.org...
appearance
Trek - Next
quite
> satisfying.
> thanks in advance
> GB
