POV-Ray : Newsgroups : povray.animations : Doesn't run ini correctly Server Time
28 Jul 2024 18:21:33 EDT (-0400)
  Doesn't run ini correctly (Message 1 to 4 of 4)
Subject: Doesn't run ini correctly
Date: 22 Aug 1999 15:14:08
Message: <37c04c00@news.povray.org>
Pov-Win 3.1(eg not command line) doesn't run my inis correctly. I have
set it up so that I run the inis from the command line, but they don't run.
All it runs is the file I have set as the the secondary ini in the edit
settings-Render menu.
And when I run the other ini file that way that is the only way I can get it
to observe
the Input_File_Name option.
webpage: http://johntb.freeservers.com
ICQ:20886467 AIM:Qbwiz
 Version: 3.12
G! d- s--:- a---- C++ ULU++++ P+  L+ E W++ N++ o K- w+
O! M- V- PS PE+ Y+ PGP- t+@ 5 X R tv+ b++ DI++++ D-
G e-- h! !r y-
Subject: Re: Doesn't run ini correctly
Date: 23 Aug 1999 15:34:13
Message: <37c1a235@news.povray.org>
Are you using +i or Input_File_Name? Actually either way works okay
for me here using v3.1g for Win. Maybe I'm not understanding the
problem exactly.
John Bauman <bau### [at] ptdprolognet> wrote in message
news:37c04c00@news.povray.org...
have
don't run.
edit
can get it
> to observe
> -----BEGIN GEEK CODE BLOCK-----
>  Version: 3.12
> G e-- h! !r y-
> ------END GEEK CODE BLOCK------
Date: 23 Aug 1999 17:25:21
Message: <37c1bc41@news.povray.org>
I don't use +i, but I do use Input_File_Name.
Normally, when I run An ini file, using the secondary ini setting,
in Edit Settings,Render, It ignores that line and runs the file that had
been selected down below.When I run an ini file from the command line(no
switches), it runs the one that I had put in the secondary ini place
correctly, including using the Input_file_Name . But I want it to run the
one I sent to it on the command line.
Bob Hughes wrote in message <37c1a235@news.povray.org>...
>problem exactly.
>Bob
>have
>don't run.
>edit
>can get it
>> to observe
>>  Version: 3.12
>> G e-- h! !r y-
Date: 24 Aug 1999 06:51:49
Message: <37c27945@news.povray.org>
My mind is like a sieve, so please excuse my not understanding.
However whatever I try does work it seems, just not sure what you are
trying to do exactly, which is always the difficulty when attempting
to understand someone elses dilemma. You are not putting a Ini file in
to be rendered as the Input file are you? That is the only thing I can
see that might be wrong, as such a file will not render.
Ah, I think I'm seeing it now. You need the Ini to take control at the
command line level. My lack of intelligence is showing.... You don't
use the Input_File_Name anyhow to specify the Ini, so that's cleared
up okay, right? You just want to put the Ini file name alone in the
command line field is all to use it. And guess what, I just tested to
make sure it works and it did not! Says the Ini is in error somehow.
Ah ha (again), there needs to be a Library_Path (+L) leading to the
Ini containing folder. I will now hand it back over to you, with
blessings ;)
news:37c1bc41@news.povray.org...
had
line(no
run the
> >problem exactly.
> >Bob
> >have
> >don't run.
the
> >edit
> >can get it
> >> to observe
> >>  Version: 3.12
> >> G e-- h! !r y-
