POV-Ray : Newsgroups : povray.animations : more memory for cmpeg Server Time
28 Jul 2024 18:20:41 EDT (-0400)
  more memory for cmpeg (Message 1 to 3 of 3)
Subject: more memory for cmpeg
Date: 15 Jul 1999 14:30:16
Message: <378e28b8@news.povray.org>
cmpeg always quits with this error on startup of it:
Image type: TGA24
Image size: 512x384
Encoding 200 frames
malloc failed
I figure thats because its taking up too much memory, but I gave it
all the conventional memory I could, so what could I do?
webpage: http://johntb.freeservers.com
ICQ:20886467 AIM:Qbwiz
 Version: 3.12
G! d- s--:- a---- C++ ULU++++ P+  L+ E W++ N++ o K- w+
O! M- V- PS PE+ Y+ PGP- t+@ 5 X R tv+ b++ DI++++ D-
G e-- h! !r y-
Subject: Re: more memory for cmpeg
Date: 15 Jul 1999 23:48:15
Message: <378EAB56.FD9E3D99@aol.com>
You could try batch converting your 24bit targa files to 15bit if you
have a program that can do so (uncompressed tga is important to keep).
Supposedly the resulting animation is larger but the two memory "images"
will require less space.
> Image type: TGA24
> Image size: 512x384
> Encoding 200 frames
> malloc failed
> -----BEGIN GEEK CODE BLOCK-----
>  Version: 3.12
> G e-- h! !r y-
> ------END GEEK CODE BLOCK------
 mailto://inversez@aol.com?Subject=PoV-News
Date: 16 Jul 1999 14:02:42
Message: <378f73c2@news.povray.org>
Hello,
Do you have XMS drivers running? Any other background drives should be
disabled and then Cmpeg usually runs fine. It should be run from the DOS
Prompt, not a DOS instance under Windows.
I have always found that booting from a floppy can be a good idea.
Altrentivly you could obtain a better MPEG compiler. MPEG 2 is much better
than MPEG 1. The only problem is that fewer people have access.
Luke
John Bauman wrote in message <378e28b8@news.povray.org>...
>Image type: TGA24
>Image size: 512x384
>Encoding 200 frames
>malloc failed
> Version: 3.12
>G e-- h! !r y-
