POV-Ray : Newsgroups : povray.animations : Now What??? Server Time
28 Jul 2024 20:35:08 EDT (-0400)
  Now What??? (Message 1 to 4 of 4)
Subject: Now What???
Date: 27 Mar 1999 20:05:48
Message: <36FD7F59.2BBE@prodigy.net>
Thanks for the help.  I am now one step closre to figuring out how to
animate a scene.  I just understood all the internal animation loops and
what I have to do to set up the scene.  I just produced 100 still
images  and I have DTA but what I need to know is how to I get DTA to
put my images together for the complete animation?
Subject: Re: Now What???
Date: 28 Mar 1999 01:49:24
Message: <36FDD0E6.D1B5F0FC@aol.com>
I've tried DTA before using one the INI files before and there was a
problem with running the DOS version (2.2.7?). A command interpreter had
to be invoked, thusly:
Post_Scene_Command=command.com /C C:\POVanim\Dta
/oC:\POVanim\View\%s.flt C:\POVanim\Create\%s*.tga
DTA.exe being in the POVanim directory in this case, and %s inserts the
files name (the name being less any letters to compensate for any
replacing frame numbers). The resulting animation written to a View
subdirectory. The POV-Ray output going into the Create subdirectory,
obviously, first.
Seems this isn't in the original files as such.
Not positive this works, but since it was there in my POV-Ray\renderer
folder and I had used this before it should.
Date: 28 Mar 1999 02:00:26
Message: <36FDD33F.A1B45152@aol.com>
I also made a batch file to do this external of POV-Ray, in a DOS
window, so just ask and you shall receive.
Neglected to mention you will need to use other than PNG output from
POV-Ray far as I know. Unless someone knows otherwise.
Date: 18 May 1999 04:05:06
Message: <37411122.0@news.povray.org>
No, dta understands png format. The problem is that dfv will not play it
right, but you can build it into a self-viewable file with buildsv and
everything works great.
GrimDude
vos### [at] arkansasnet
