![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Hello!
I need to animate a cylinder by random scaling it up and down in y axis but
a only want to scale from 0.9 to 1.1. How can I get a random number and get
sure that falls between 0.9 and 1.1.
I've tried with rand(seed(clock)) but can't get there.
Sergio
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Inexistencia-Design, Dec. P. Eventos Lda wrote:
> Hello!
> Sergio
Hi Sergio!
I tried this and it worked the I I think you meant.
camera {location <0,2,-2>
look_at 0}
light_source {<1,1,-1> color rgb<1,1,1>}
#declare RAND1 = seed(12345+(clock*10));
cylinder {0,y,0.25
pigment{color rgb <1,0,0>}
scale <1,0.9 + (0.2 * rand(RAND1)),1> }
Marc
Marc Schimmler
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Hello!
> Sergio
This pair of macros will yield a random-number that varies smoothly
over time. To use these macros, first #declare an array of four scalars
and pass it to SmoothSeed( ). The macro will use the array to hold the
seed( ) values for the four random-number sequences derived from the
clock variable. Sequence is used to select the sequence to be used for
generating the random numbers.
Once SmoothSeed( ) is called, SmoothRand( ) will return a random number
from 0 to 1. Subsequent calls to the macro within an animation frame will
vary independently from each other, but the values themselves will vary
smoothly from frame to frame.
//example scene code
#declare MyArray=array[4] {0,0,0,0}
SmoothSeed(MyArray,0)
sphere { y*(10+10*SmoothRand(MyArray)),1
pigment { MyPigment }
When animated, this will give a sphere that rises and falls randomly.
Code:
#macro SmoothSeed(Array,Seq)
#declare Array[0]= seed(floor(clock-1)+Seq);
#declare Array[1]= seed(floor(clock)+Seq);
#declare Array[2]= seed(floor(clock+1)+Seq);
#declare Array[3]= seed(floor(clock+2)+Seq);
#macro SmoothRand(Array)
#local t_T=clock-floor(clock);
#local t_R0=rand(Array[0]);
#local t_R1=rand(Array[1]);
#local t_R2=rand(Array[2]);
#local t_R3=rand(Array[3]);
#local t_C0=t_R1;
#local t_C1=(t_R2-t_R0)*.5;
#local t_C2=t_R0 - 2.5*t_R1 +2*t_R2-.5*t_R3;
#local t_C3=-.5*t_R0 +1.5*t_R1 -1.5*t_R2 +.5*t_R3;
(((((t_C3*t_T+t_C2)*t_T+t_C1)*t_T+t_C0)*.8)+.1)
Ken Tyler
mailto://tylereng@pacbell.net
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
#declare HighPoint = 1.1;
#declare LowPoint = 0.9;
#declare Range = HighPoint - LowPoint;
#declare R1 = seed(42);
#declare MyRandomNumber = rand(R1)*Range + LowPoint;
This gives you a random number between those two points
"Inexistencia-Design, Dec. P. Eventos Lda" wrote:
> Hello!
> Sergio
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
