POV-Ray : Newsgroups : povray.animations : Animation Newbie Alert! Server Time
28 Jul 2024 22:27:06 EDT (-0400)
  Animation Newbie Alert! (Message 1 to 2 of 2)
Subject: Animation Newbie Alert!
Date: 18 Dec 1998 11:47:01
Message: <368E4D82.E0D89C23@turbont.net>
I'm afraid you must get a lot of these, but...does anyone feel like
explaining the POV animation system to me?  The documentation is quite
confusing.
-Joe Prever
Subject: Re: Animation Newbie Alert!
Date: 18 Dec 1998 12:20:54
Message: <367a8ef6.0@news.povray.org>
Basically,  in an .ini file you specify the number of images to produce from
your .pov file.  In this file you also specify a clock value - its starting
and ending values.  In your pov source, use the clock variable to translate,
scale, or rotate your objects.  A statement in your pov source may look like
this:
box{<-1,-1,-1><1,1,1> rotate<360*clock,0,0> texture{yada..yada..yada..}}
If you specify in the ini file 360 frames, a clock start of 0 and clock end
of 1, the box above will rotate in a complete circle throughout the 360
images generated.
For those of you well versed in the animation techniques, I know this is not
efficient and the same can be done with 90 frames and using 90*clock....
Good luck Joseph.
Mike
Joseph Prever wrote in message <368E4D82.E0D89C23@turbont.net>...
>confusing.
>-Joe Prever
