POV-Ray : Newsgroups : povray.animations : Animating Isosurface question Server Time
6 Oct 2024 09:47:45 EDT (-0400)
  Animating Isosurface question (Message 1 to 6 of 6)
Subject: Animating Isosurface question
Date: 17 Jan 2003 08:51:07
Message: <3e280a4b@news.povray.org>
Hello,
I have an isosurface with two forms, as follows:
#declare P1=function{pigment{leopard
   colour_map{[0.0  rgb 0.3]
              [0.1  rgb 0.0]
              [1.0  rgb -.3]}
   scale 0.15
#declare P2=function{pigment{leopard
   colour_map{[0.0  rgb 0.1]
              [0.1  rgb 0.0]
              [1.0  rgb 1.8]}
   scale 0.15
I'd like to be able to animate the transition between the two forms. I have
clockmod and have studied the tutorials, but the answer doesn't seem to be
there. Is there a way to do this?
Thasnk you,
Steve Shelby
Subject: Re: Animating Isosurface question
Date: 17 Jan 2003 08:56:26
Message: <1j2g2vorak2gve9rrinj1d1ffu6hu4dlef@4ax.com>
On Fri, 17 Jan 2003 08:57:17 -0500, "Steve Shelby" <ssh### [at] rexnetnet> wrote:
> #declare P1=function{pigment{leopard ...
> #declare P2=function{pigment{leopard ...
assuming clock goes from 0 to 1 it could be something like:
  #declare P=function{(1-clock)*P1(x,y,z).gray+clock*P2(x,y,z).gray};
such solution in extended form was used in:
http://news.povray.org/povray.binaries.animations/23891/167475/wip.mpg
ABX
Date: 17 Jan 2003 12:49:10
Message: <3e284216@news.povray.org>
"Steve Shelby" <ssh### [at] rexnetnet> wrote in message news:3e280a4b@news.povray.org...
> Hello,
>               [0.1  rgb 0.0]
>               [1.0  rgb -.3]}
>    scale 0.15
>               [0.1  rgb 0.0]
>               [1.0  rgb 1.8]}
>    scale 0.15
A more easily understandable way of doing it (for those who, like me, have limited
math
skills) would be:
#include "AutoClck.mcr"
#declare Val_1=0.3;
Declare_From (Val_1,0)
Declare_To_Using (Val_1,1,0.1,"S")
#declare Val_2=-0.3;
Declare_From (Val_2,0)
Declare_To_Using (Val_2,1,1.8,"S")
    colour_map{[0.0  rgb Val_1]
               [0.1  rgb 0.0]
               [1.0  rgb Val_2]}
    scale 0.15
This is untested, but it should work.
All the best,
Andy Cocker
Date: 18 Jan 2003 09:57:23
Message: <3e296b53@news.povray.org>
ABX,
Thanks for your reply. That animation is awesome. I forgot to include in my
first post the next line of the isosurface, which is:
isosurface {
   function { y -P (x,0,z).red*0.4}
If  I make P either P1 or P2 it will render, but not just P and the line you
showed me. I'm in over my head with this, so I'm either going to need expert
help or wait until I have enough experience to understand it better.
Steve
ABX <abx### [at] abxartpl> wrote in message
news:1j2g2vorak2gve9rrinj1d1ffu6hu4dlef@4ax.com...
> ABX
Date: 18 Jan 2003 10:01:06
Message: <3e296c32@news.povray.org>
Andrew,
I tried it, no luck. but I just realized I forgot to include the next line
defining the isosurface, which is:
isosurface {
   function { y -P1 (x,0,z).red*0.4}
If that makes any difference.
Steve
Andrew Cocker <mai### [at] andrewcockercouk> wrote in message
news:3e284216@news.povray.org...
> > Hello,
> >               [0.1  rgb 0.0]
> >               [1.0  rgb -.3]}
> >    scale 0.15
> >               [0.1  rgb 0.0]
> >               [1.0  rgb 1.8]}
> >    scale 0.15
have
be
limited math
> skills) would be:
> #declare Val_1=0.3;
>                [0.1  rgb 0.0]
>                [1.0  rgb Val_2]}
>     scale 0.15
> All the best,
> Andy Cocker
Date: 18 Jan 2003 20:42:32
Message: <3e2a0288@news.povray.org>
Success!
After sending the previous message, I realized that the line you sent was
similar to the line I had just sent. After some experimentation, I  arrived
at the following:
isosurface {
   function { y -(1-clock)* P1 (x,0,z).red*0.4-clock*P2(x,0,z).red*0.4}
It works exactly as desired. I'm posting a clip (with 2nd half of loop added
in VideoMach) in povray.binaries.animations.
Thanks a lot for helping me with this.
Steve
> ABX
