POV-Ray : Newsgroups : povray.animations : cmpeg question Server Time
28 Jul 2024 14:18:09 EDT (-0400)
  cmpeg question (Message 1 to 5 of 5)
Subject: cmpeg question
Date: 24 Aug 2000 02:04:25
Message: <01c00d91$2aa131c0$667dd383@etnica.ibb.uu.nl>
Hello,
I downloaded cmpeg and made an animation which was included in the povray
package. I noticed that the last frame is not present in the animation. Can
someone explain me why this happens or what could be done about it. Except
including the last image twice in the file-list.
thanks,
Koos
Subject: Re: cmpeg question
Date: 24 Aug 2000 07:41:33
Message: <39A509ED.4D3CD3A4@erols.com>
If you're using MicroSuck Media Player, that's the reason you can't see
the last frame.
Date: 24 Aug 2000 11:13:53
Message: <01c00ddd$ed1ce040$667dd383@etnica.ibb.uu.nl>
that explains a lot but which player would you then recommend?
John VanSickle <van### [at] erolscom> schreef in artikel
<39A509ED.4D3CD3A4@erols.com>...
> the last frame.
Date: 24 Aug 2000 11:56:30
Message: <39a545ad@news.povray.org>
Btw, if the last frame would be a B-frame, what does the encoder do? How
can it create it since it doesn't have the following I or P frame?
Date: 25 Aug 2000 07:27:54
Message: <39A65839.5F989FA6@erols.com>
> How can it create it since it doesn't have the following I or P frame?
It skips that frame coding spec and goes to the next non-B spec.  For
instance, if you specify
BBIBBP
in your CTL file, the frame type in a 24-frame animation will be
assigned this way:
IBB PBB IBB PBB IBB PBB IBB PBI
If your CTL specified this:
BBIBBPBBP
The frame types would be assigned like this:
IBB PBB PBB IBB PBB PBB IBB PBP
If you use option -v1 in the CMPEG command line, it will tell you what
frame type is being used for each frame.
John
