POV-Ray : Newsgroups : povray.advanced-users : Making Patterns with functions Server Time
11 Oct 2025 07:29:32 EDT (-0400)
  Making Patterns with functions (Message 51 to 56 of 56)
Subject: Re: Making Patterns with functions
Date: 25 Feb 2025 02:34:01
Message: <67bd7269$1@news.povray.org>
On 25/02/2025 03:02, Bald Eagle wrote:
> Was setting up a basic scene for a completely unrelated pattern, and came up
> with this.
> Trying to consistently get functions to behave consistently across N=0 is a
> giant PITA in POV-Ray, when I don't think it ought to be.
Really impressive patterns. What a good job.
Just for a french reader, what PITA meens ?
kurtz le pirate
compagnie de la banquise
Date: 25 Feb 2025 04:54:19
Message: <67bd934b$1@news.povray.org>
Pain in the ass.
Ilyich the Toad
https://dnyarri.github.io/
Date: 25 Feb 2025 05:03:17
Message: <67bd9565$1@news.povray.org>
> with this.
I really like this one!
Bill P.
Date: 25 Feb 2025 06:40:00
Message: <web.67bdaae1d81b84791f9dae3025979125@news.povray.org>
> > with this.
> Bill P.
Super.  Maybe you can help me understand why I always have to go through a NEW
form of calisthenics when I cross zero.
(and as you can see, the pattern function is dirt simple)
#version 3.8;
global_settings {assumed_gamma 1}
default {finish {diffuse 1}}
//#include "colors.inc"
#include "functions.inc"
#include "math.inc"
#declare E = 0.000001;
#declare Zoom = 20;
 orthographic
 location <0, 0, -50>
 right x*image_width/Zoom
 up y*image_height/Zoom
 look_at <0, 0, 0>
 rotate y*0
sky_sphere {pigment {rgb 1}}
light_source {<0, 0, -50> rgb 1}
#declare fmod = function (Value, Modulo) {select (Value, 1 - mod (abs (Value),
Modulo), mod (abs (Value), Modulo))}  // this gives a mod function that remains
consistant across the origin
#declare Formula1 = function {(y-sin(x))*(y-cos(x))}  // graphs 2 functions
simultaneously
#declare Formula2 = function {
 select (y,
 select (odd(floor(y/2)), 0, (fmod(y, 2)-sin(x))*(fmod(y, 2)-cos(x)), (fmod(y,
2)+sin(x))*(fmod(y, 2)+cos(x)) ),
 select (odd(floor(y/2)), 0, (fmod(y, 2)-1-sin(x))*(fmod(y, 2)-1-cos(x)),
(fmod(y, 2)-1+sin(x))*(fmod(y, 2)-1+cos(x)) ) // why?
// debugging loop
#for (Y, -10, 10)
 #declare Value = odd(floor(Y/2));
 #declare Value2 = fmod(Y,2);
 #debug concat (" Y = ", str(Y, 0, 0),  "     Value = ", str(Value, 0, 0), "
Value2 = ", str(Value, 0, 0), "\n")
#declare Formula = function {Formula2 (x, y, z)}
#declare RawPattern = pigment {function {Formula (x, y, z)}}
#declare Thickness = 0.1;
#declare LinePattern = pigment {function {select (abs (Formula (x, y, z)) -
Thickness, 0, 1)}}    // Once (<=1)
#declare LinePattern2 = pigment {function {select (abs (mod (Formula (x, y, z),
1)) - Thickness, 0, 1)}}
plane {z, 0 texture {pigment {LinePattern} finish {diffuse 1}} translate -z*0.1}
Date: 25 Feb 2025 18:22:52
Message: <67be50cc@news.povray.org>
If you are working with an equation you wish to use as a pattern, and
the value of y, say, crossing through 0.0 flips or changes the
function's behavior, one must deal with it in some way.
In your particular function there is a flip in behavior due internal
value changes away from zero and another due y changing sign.
Below a yuqk fork scene showing some typical ways for dealing with value
transitions causing unwanted change with your function based pattern.
Some work with official POV-Ray releases too. To reproduce your result,
however, we might need to do something pretty close to what you did! I
didn't try to exactly match your posted result.
     // Sample scene. 'yuqk y_cross_0.pov +w1024 +h768 +p +mv3.8'
     global_settings { assumed_gamma 1.0 }
     #declare VarOrthoMult =
        20.0/max(image_width/image_height,image_height/image_width);
     #declare Camera01z = camera {
         orthographic
         location <0,0,-2>
         direction z
         right VarOrthoMult*x*max(1,image_width/image_height)
         up VarOrthoMult*y*max(1,image_height/image_width)
     // 'odd()' is one of the fake keywords shipped with official
     // POV-Ray which the yuqk fork removed.
     #include "munctions.inc"
     #local Dummy   = M_odd(0.5); // compiling F_odd()
     #local EvenOdd = M_odd(0);   // Later calls run F_odd internally
     #local EvenOdd = F_odd(2);   // = 0
     #local EvenOdd = F_odd(3);   // = 1
     #declare Formula1 = function { (y-sin(x))*(y-cos(x)) }
     // When y moving through zero flips results, it's typical to use
     // pattern value modifiers or similar inbuilt functions.
#if     (1)  // Call as FnY(0,y/2,0)
     #declare FnY = function {
         pattern { gradient y triangle_wave }
#elseif (0)  // Call as FnY(0,y/4,0)
         pattern { gradient y function_interval triangle_wave }
#elseif (0)  // Call as FnY(0,y/2,0)
         f_triangle_wave(y,0)
         f_triangle_wave(y,1)
#else
     #error "Must pick a definition of function Fny()\n"
         pattern {
             function { Formula1(x,y,z) }
             triangle_wave
             frequency 4
     #declare Formula3 = function { // Push y positive
         Formula1(x,
             select(
                 F_odd(f_round(y+100+0.5)),
                 0,
                 mod(y+100,1),
                 1-mod(y+100,1)),0)
     #declare FnLine = function {
         select(((Formula2(x,y,z)>-0.1) & (Formula2(x,y,z)<0.1)),
             0, 0, 1)
     plane { -z 0
           //function { Formula1(x,y,z) }
           //function { Formula1(x,FnY(0,y/2,0),z) }
           //function { Formula2(x,FnY(0,y/2,0),z) }
             function { FnLine(  x,FnY(0,y/2,0),z) }
           //function { Formula3(x,           y,z) }
           //raw_wave
             color_map {
                 [-2 rgb <1,0,0>]
                 [-0.01 rgb 0]
                 [+0.01 rgb 0]
                 [+2 rgb <0,1,0>]
         finish { emission 1 }
     camera { Camera01z }
#if (0)
     union {
         sphere {<0, 0,0> , 0.1 }
         sphere {<0,+1,0> , 0.1 }
         sphere {<0,+2,0> , 0.1 }
         sphere {<0,-1,0> , 0.1 }
         sphere {<0,-2,0> , 0.1 }
         pigment { rgb <1,0,0>} finish { emission 1 }
Image attached.
Bill P.
Download 'y_cross0.png' (415 KB)
Preview of image 'y_cross0.png'
Date: 1 Mar 2025 10:40:00
Message: <web.67c32942d81b847943a63f5189db30a9@news.povray.org>
> Image attached.
I like this pattern.
It's lovely!
Tor Olav
http://subcube.com
https://github.com/t-o-k
