POV-Ray : Newsgroups : povray.advanced-users : Mesh2 and image maps Server Time
2 Jan 2025 09:58:56 EST (-0500)
  Mesh2 and image maps (Message 1 to 3 of 3)
Subject: Mesh2 and image maps
Date: 29 Feb 2020 17:40:01
Message: <web.5e5ae640f40fb85646354ef40@news.povray.org>
I was making my own Mesh2 pulleys belts. Every thing work find or so I thought.
I test the mesh2 using solid colors and color maps with Normals Finishs in a
complicated texture.
Then I found out that part of the mesh worked back on it self. When I fix that
and tried color map or image maps it froze. That is :: if you try to translate
the texture then put it on the mesh The IMAGEs don't move! But the Normals do!
I've never seen anything like it.
 I'm running 3.7 I've try it on 3.6 with the same effect.
Without getting into the code to much
The texture ::
#local BTex=array[4];
#local BTex[0]=texture{pigment{rgb<1,0,0>}
                       normal{agate scale <10/60,.05,.1>}}
#local BTex[1]=texture{pigment{rgb<0,1,0>}
                       normal{agate scale<1/50,.1,1>} }
#local BTex[2]=texture{pigment{rgb<0,0,1>} normal{agate scale<.2,1,1>}
                       finish{phong .3 phong_size 250}}
#local BTex[3]=texture{pigment{image_map{tga "Road6.tga"} scale <1/25,-.49,1>
                       translate <5,.51,0>}
                       normal{granite  scale<1,1,1>}
                       finish{phong .8 phong_size 250}}
The final texture::
#local BTexX=texture{gradient y
              texture_map{
                           [0.010284 BTex[0]]
                           [0.010284 BTex[1]]
                           [0.5 BTex[1]]
                           [0.5 BTex[2]]
                           [0.510284 BTex[2]]
                           [0.510284 BTex[3]]
                           [1 BTex[3]]
                         translate x*B_TexLoc//animation texture move
I've set the uv vectors from <0,0> to <1,1>
Anyone seen this before?
Subject: Re: Mesh2 and image maps
Date: 1 Mar 2020 08:31:30
Message: <5e5bb932$1@news.povray.org>
Hi Leroy,
Not here. Perhaps someone using meshes regularly understands why you see
what you see. I'll offer guesses/rambling in the meantime - while having
a feeling you are using the mesh uv mapping mechanism in a somewhat
unusual way.
- In my experience the mesh image maps would point into the image,
texture or material with uv vectors in some sort of fixed / one time
way. Perhaps this behavior is hard coded in a way that bypasses a
texture's modifiers for image maps? The normals you specified would be
outside any fixed uv image mechanism - if such a thing exists. Hmm, what
happens if you use something other than an image_map with BTex[3] - some
gradient x pattern with vertical stripes maybe? Does that then move with
the normals?
- It looks like the BTexX translate is in x only. Have you tried an off
axis translation to be sure you are not hitting some sort of harmonic
with the image movement where it happens to be the same at every B_TexLoc?
- When you say you've set the uv vectors in the mesh, I assume you mean
you are pointing mesh vertexes at the appropriate locations in the BTexX
texture. I suppose you're aligning those with the gradient y in some
fashion(1).
I've played with meshes in mapping other formats into POV-Ray and doing
simple stuff color to vertex stuff, but, my understanding of how the
POV-Ray uv mesh mechanism 'really works' is shallow(2).
Bill P.
(1) - Find myself wondering whether uv coordinates outside the <0,0> to
<1,1> range would work... I can't now see any reason they couldn't
function. Suppose, I'm wondering too, if texture movement could be
accomplished by shifting the uv vectors for each frame. Today, we reload
everything in the scene for each frame - so should work I think, and
even if constrained in the 0-1 range. Hmm, Could make for some
interesting animations shifting materials/textures around on an incoming
mesh - blurring a mesh model's materials by merging frames. Anyway...
(2) - With mesh image mapping, wondered how the mesh mapping pros handle
an image's interpolation seams. Are appropriate extra pixels carefully
added to the images internal edges/cut-outs to be sure any 'image'
interpolation results in a clean texture on the mesh at those seams?
Does such a thing happen by side effect of mesh painting - is there some
overspray area? I'm curious if anyone knows - otherwise, someday maybe
I'll investigate. You've mapped without POV-Ray image interpolation /
smoothing, so my question matters not in your scene.
Date: 6 Mar 2020 22:10:00
Message: <web.5e630f6e6524ec49f7d4608f0@news.povray.org>
William F Pokorny <ano### [at] anonymousorg> wrote:
> Hi Leroy,
> unusual way.
First off I want to apologize for being so late getting back here.
 And you need to know that as soon as I got off line I found the problem was all
in the way I used the image map. Before I did my 'fix' I had the uv fitted to
the mesh in a 1 to belt length style <0,0> to <1,Belt length> so any image would
fit the belt.
 After the 'fix' it was <0,0> to <1,1>, While testing, I plane forgot what I
just did and was scaling the image map to fit the old style of uv mapping.
Now I didn't use the once in the image map, so I got repeat images. And my test
values to move the texture just happen to keep the image map in the same place
but the normals where where moved!
 So now we have an new effect. When the image is frozen and the normals move you
can have gost floating across the screen. My test image was a landscape and it
made it look like clouds floating over head.
> way.
Your completely  right there.
> fashion(1).
I'll answer this here and drop (1)
Your Right in what I did. I wrapped the uv mapping around a belt so that each
face of the belt match one of the textures in BTexX.
> Bill P.
 I haven't used many other Mesh making programs. Blender the one that comes to
mind and I never did get into the image mapping part. I have seen some of the
images used by other Mesh programs. They are always tied to a single mesh.
Thanks for you thoughts.
Have Fun
