POV-Ray : Newsgroups : povray.advanced-users : Photons, in version 3.6 to 3.7 Server Time
8 Feb 2026 01:20:11 EST (-0500)
  Photons, in version 3.6 to 3.7 (Message 1 to 10 of 18)
Subject: Photons, in version 3.6 to 3.7
Date: 7 May 2019 12:30:01
Message: <web.5cd1b2029bc1f54337fe761b0@news.povray.org>
With 3.6 version, i use a photon #macro like under this line, and the 'no_image'
for object, to see the refraction appeer on a plane and it's ok.
But with the 3.7 version, and the same file, there is nothing appeer on plane,
and no photons count on render.
#macro PhotonBlock()
 #if(Photons)
  photons {
   target
   collect off
   reflection off
   refraction on
Do you see a solution with 3.7 language ?
Albun
Subject: Re: Photons, in version 3.6 to 3.7
Date: 8 May 2019 02:41:28
Message: <5cd27a18$1@news.povray.org>
On 7-5-2019 18:28, Albun wrote:
> Hi,
>   #if(Photons)
>    photons {
>     target
>     collect off
>     reflection off
>     refraction on
>   #end
> #end
You didn't tell, do you have a photons statement in the global_settings?
That is essential.
either:
global_settings {
   photons {
     spacing 0.02
or:
global_settings {
   photons {
     count 1000
Also, the photons-receiving objects need a photons definition, like the
following example:
plane {
   y, 0
     pigment { color srgb <1.0, 0.8, 0.6> }
    photons {collect on}
Maybe also the light source:
light_source {
   <100, 300, 500>
   color rgb 1.0
   parallel
   photons {
     refraction on
     reflection on
See the appropriate sections in the docs.
Date: 8 May 2019 09:50:00
Message: <web.5cd2dd748f793cd437fe761b0@news.povray.org>
Well Thomas,
ok for global setting with spacing
ok for color srgb
ok for light and object collect photon
ok for render photons count
but with the 'no_image' in object no ok, and no photons count in render.
May i will use only 3.6 version for this file...
Albun
Date: 8 May 2019 10:15:01
Message: <web.5cd2e3a88f793cd437fe761b0@news.povray.org>
Here is the file, no_image is in sphere.
#version 3.7;
#declare Camera_0 = camera {perspective angle 75               // front view
                            location  <0.0 , 1.0 ,-3.0>
                            look_at   <0.0 , 1.0 , 0.0>}
camera{Camera_0}
#declare Photons = on;
#declare Interior =
interior {
 fade_distance 2
 fade_power 3
 ior 1.45
 dispersion .05
 dispersion_samples 12
 #if(Photons)
  photons {
   target
   collect off
   reflection off
   refraction on
#declare Intensity = 12;
#declare L_Fade_Distance = 40;
#declare L_Fade_Power = 1;
#declare Area_Light=off;
#declare ALL = 1;//area light height (width?)
#declare ALW = 8;//area light width
#declare ALR = 5;//area light resolution
global_settings { ambient_light .1
 assumed_gamma 1.3
 max_trace_level 5
 #if(Photons)
  photons {spacing 0.0015}  //0.015
light_source{< 0,0,30> White*Intensity
 #if(Area_Light)
  area_light x*ALL, z*ALW, ALR, ALR
  adaptive 1
  jitter
 fade_distance L_Fade_Distance
 fade_power L_Fade_Power
 #if(Photons)
  photons {refraction on reflection off}
rotate<-5,0,0>
// sky ----------------------------------------------------------------------
sky_sphere { pigment { gradient <0,1,0>
                       color_map { [0.00 srgb <0.6,0.7,1.0>]
                                   [0.35 srgb <0.1,0.0,0.8>]
                                   [0.65 srgb <0.1,0.0,0.8>]
                                   [1.00 srgb <0.6,0.7,1.0>]
                       scale 2
                     } // end of pigment
           } //end of skysphere
// ground -------------------------------------------------------------------
plane{ <0,1,0>, 0
       texture{ pigment{ checker color srgb<.8,.8,.8> color srgb<0.5,0.5,0.5>*1}
              } // end of texture
     } // end of plane
//---------------------------- objects in scene ----------------------------
 #declare GlassTex =
 pigment {color srgbf <1, 1, 1, 1>}
 finish {
  reflection 0.05
  specular 1
  roughness 0.001
  metallic on
  irid {0.65             // contribution to overall color
   thickness 0.8    // affects frequency, or "busy-ness"
   turbulence 0.1   // Variance in film thickness
// sample sphere
sphere { <0,0,0>, 1.00
         texture { GlassTex} // end of texture
         interior {Interior}
 PhotonBlock()
        no_image   ///////////////////////
          scale<1,1,1>  rotate<0,0,0>  translate<0,1.35,0>
       }  // end of sphere -----------------------------------
Date: 8 May 2019 16:01:49
Message: <5cd335ad@news.povray.org>
Le 19-05-08 à 10:11, Albun a écrit :
Can you try using the object's photons block without the macro?
It's OK for any object to have a photons block in a non-photons scene.
It will just have no effect.
Your sample sphere will look like :
          interior {Interior}
//// The following is a "no op" in non-photon scene /////////
  photons {
    target
    collect off
    reflection off
    refraction on
Date: 8 May 2019 19:57:52
Message: <5cd36d00$1@news.povray.org>
Thanks. I can see that the no_image behavior is different 3.6 to
3.7/3.8. Anyone know if such a change was intentional for some reason?
FYI. I moved the light source to a z of 300 and then rotated -55*x to
get photons on the plane with your camera set up. Otherwise - with the
point light at least - the photons mostly miss the plane off the bottom
of the image. I also took your light intensity down from 12 to 1 to
prevent white out.
Bill P.
Date: 9 May 2019 04:55:01
Message: <web.5cd3ea7c8f793cd437fe761b0@news.povray.org>
So, with or without macro, with no_image the render do the same result, and no
photons count in 3.7.
Who can tell better ?
Thanks all
Albun
Date: 9 May 2019 09:02:43
Message: <5cd424f3$1@news.povray.org>
> Thanks all
> Albun
It happens I've been working some in the photon code for another
investigation so I started to dig here. I have to take a short break but
what I've found so far is that having the no_image or not changes
whether the following test:
if (Test_Flag(bestisect.Object, PH_TARGET_FLAG))
in PhotonTrace::TraceRay in photons.cpp is true.
I thought, OK, it must be a parser issue and started to look at things
from that end. But, the sphere's PH_TARGET_FLAG is true with and without
the no_image flag checking just after the
Parse_Object_Mods(reinterpret_cast<ObjectPtr>(Object));
call in ObjectPtr Parser::Parse_Sphere() in parser.cpp.
So... I still don't know what's going on, but looking like the sphere's
photon target flag is changing state sometime after being set correctly
in the parser and before the photon TraceRay call due the no_image modifier.
More when I get back to it - unless someone beats me to it.
Bill P.
Date: 9 May 2019 10:40:00
Message: <web.5cd43aa58f793cd437fe761b0@news.povray.org>
For the moved light, and any other set up, it's another beautyful aspect.
But i stay right in my boots for that ....;-)))
For the code, i havent an idea about what happen with the source.
But i understand that is not easy to really know all
thing happen in the 'troubling unknowquantic rendering',
if i can naming it like that.
Albun
Date: 9 May 2019 14:51:12
Message: <5cd476a0$1@news.povray.org>
> Albun
OK. The actual issue is in the PhotonTrace::TraceRay code in photons.cpp
where we have:
     found = FindIntersection(bestisect, ray, precond, postcond);
     if(found)
this borrows 'NoSomethingFlagRayObjectCondition precond' from trace.cpp
which starts off with:
bool NoSomethingFlagRayObjectCondition::operator()(const Ray& ray,
ConstObjectPtr object, double) const
     if(ray.IsImageRay() && Test_Flag(object, NO_IMAGE_FLAG))
         return false;
which returns false because of how ray.IsImageRay() is set up. We can
hard code around the issue by changing:
to
     found = FindIntersection(bestisect, ray);
but I think the right thing to do is probably to change the
ray.IsImageRay() definition in ray.h from:
  bool IsImageRay() const { return primaryRay || (refractionRay &&
!reflectionRay && !radiosityRay); }
to:
bool IsImageRay() const { return (primaryRay && !photonRay) ||
(refractionRay && !reflectionRay && !photonRay && !radiosityRay); }
or suppose some photon code specific precond a possibility too. My guess
at the moment is that this 3.6 to 3.7 change was not intentional.
Christoph?
Bill P.
