POV-Ray : Newsgroups : povray.advanced-users : Directly accessing array value in array of arrays (Part 2) Server Time
8 Feb 2026 01:29:37 EST (-0500)
   Directly accessing array value in array of arrays (Part 2) (Message 1 to 6 of 6)
Subject: Directly accessing array value in array of arrays (Part 2)
Date: 26 Aug 2018 19:25:00
Message: <web.5b83362ac09bb9a8458c7afe0@news.povray.org>
I tracked down my old thread, but no help.
http://news.povray.org/povray.advanced-users/thread/%3Cweb.58e6aa331b66056880403a200%40news.povray.org%3E/
I have a 2D array, and I want to have that array be a collection of other 2D
arrays.
Is that allowed?
How do I access, or more importantly assign, uninitialized "internal" 2D array
elements?
#declare Array1 = array [4][4];
#declare Array2 = array [4][4];
Partially fill Array 2 with some values.
#declare Array1 [2][3] = Array2;
So far so good - but now I need to get to the "array formerly known as Array2 ",
element [0][2] which is INSIDE of Array1 [2][3]
#declare Array1[2][3][0][2] = somevalue makes the POV-Ray parser cry.
I'm none to happy about it either.
Advice?  Solution(s)?
Subject: Re: Directly accessing array value in array of arrays (Part 2)
Date: 27 Aug 2018 04:45:00
Message: <web.5b83b8fba75a4bf71500b2fd0@news.povray.org>
hi,
assign Array1[2][3] to a variable, then access that like the array.  given the
above and the four elements of Array2[1][?] set to some value, the following
works for me:
#declare TA = Array1[2][3];
#debug concat("TA 1 2", str(TA[1][2], 0, 0), "\n")
hth.
regards, jr.
Date: 27 Aug 2018 05:56:48
Message: <5b83cae0$1@news.povray.org>
Am 27.08.2018 um 01:22 schrieb Bald Eagle:
> arrays.
> Is that allowed?
Yes, absolutely - although I've heard rumors that /someone/ just
discovered a bug that may cause a crash instead of a parse error if
arrays of arrays are used and mistakes are made ;)
> elements?
Perfectly fine there.
As a side note, it might be worth mentioning that `Array1[2][3]` now
holds a /copy/ of `Array2`, not a reference.
I doubt that's what you're actually seeing, because that exact construct
works perfectly fine here.
Date: 27 Aug 2018 06:35:00
Message: <web.5b83d31ea4088b311500b2fd0@news.povray.org>
hi,
prompted me to (quick) try arrays with different dimensions contained in Array1
and found I can access all values directly through Array1, irrespective of the
number of dims.  neat + convenient.  thank you.
regards, jr.
Date: 27 Aug 2018 07:25:00
Message: <web.5b83dee3a4088b311500b2fd0@news.povray.org>
I love that this works too:
<----- snip ----->
#version 3.8;
global_settings {assumed_gamma 1}
#declare Aa = array[1][1][1][1][2];
#declare Ab = array[2][2][2][2][2];
#declare Ab[0][0][0][0][1] = 255;
#declare Aa[0][0][0][0][1] = Ab;
#debug concat("0 0 0 0 1 - 0 0 0 0 1 : ",
        str(Aa[0][0][0][0][1][0][0][0][0][1],0,0),
        ".\n")
<----- snip ----->
very neat.  :-)
Date: 27 Aug 2018 09:42:38
Message: <5b83ffce$1@news.povray.org>
Am 27.08.2018 um 13:22 schrieb jr:
> <----- snip ----->
> #version 3.8;
>         ".\n")
> <----- snip ----->
> very neat.  :-)
I /think/ you're overdoing it a bit ;)
