![](/i/fill.gif) |
"Bald Eagle" <cre### [at] netscape net> wrote:
> I wanted to make a "+"-shaped pattern by overlapping a gradient x and a gradient
> y pigment with abruptly changing color maps.
> I seemed to get the first texture I specified in the layering - when I tried to
> put a clear texture with an orthogonal stripe (0.49-0.51) on top of that, it
> occluded the first texture.
> I always have problems correctly implementing layered textures....
> Gonna head to lunch - perhaps someone has advice / examples?
Can't imagine the layer transparency obscuring the underlying texture, shouldn't
be any problem with that alone anyway.
Don't know the exact thing you're trying to make (orthogonal=horizontal by any
chance?) but here's a scene file showing either a layered pattern or image
pattern. Not sure of how good that is so beware of faults. Maybe you can get
something figured out from it.
Use your own existing render output folder/directory.
//cmd:+w500 +h500 +fn +ua +oc:\renderings\image-pattern_cross-tiles
#version 3.7;
global_settings{assumed_gamma 1}
#declare LayeredPattern=yes;
#declare CreateImageMap=no;
light_source{-9*z,1}
camera{
#if (CreateImageMap=yes)
orthographic right x*3 up y*3
location -4*z look_at 0}
background {rgb 0}
#declare GradX=
texture{
pigment{
gradient x
color_map{
[0 red 1]
//[0.49 red 1]
[0.49 rgbt 1]
[0.49 green 1]
[0.51 green 1]
[0.51 rgbt 1]
//[0.51 blue 1]
[1 blue 1]
#declare GradY=
texture{
pigment{
gradient y
color_map{
[0 red 1]
//[0.49 red 1]
[0.49 rgbt 1]
[0.49 green 1]
[0.51 green 1]
[0.51 rgbt 1]
//[0.51 blue 1]
[1 blue 1]
#declare GradXY=
pigment {green 1}
#if (LayeredPattern=no)
union{
box{-0.5,0.5
pigment {rgb 0.25} // middle dark gray
box{-0.5,0.5
pigment {rgb 1} // bottom white
translate -y}
box{-0.5,0.5
pigment {rgb 1} // top white
translate y}
box{-0.5,0.5
pigment {rgb 0.5} // left gray
translate -x}
box{-0.5,0.5
pigment {rgb 0.5} // right gray
translate x}
scale <1,1,0.01>
#else
plane{z,0
texture{
image_pattern{
png "image-pattern_cross-tiles" //use_alpha
map_type 0
once
texture_map{
[0 pigment {rgbt 1}] // outside area
[0.25 GradXY] // middle tile
[0.5 GradX] // left and right tiles
[1 GradY] // top and bottom tiles
translate -0.5 // centering
scale 3 // 1 unit boxes 3 wide, 3 tall
#else
plane{ // simple layered pattern
z,0
texture{GradX}
texture{GradY}
![](/i/fill.gif) |
![](/i/fill.gif) |
> Thanks - I eventually worked it out - it was a problem combining the remaining
> orthogonal axis, the alphabet, and the input controller.
> I did very much enjoy the cool looking pattern resulting from your code. :)
YW! I figured you just needed something to pass the time meanwhile.
![](/i/fill.gif) |
