![](/i/fill.gif) |
Has anyone had a chance to implement any of these yet?
It would be nice to have a collection of short code snippets exemplifying new
features and syntaxes for quick reference, since there seem to be a lot of new
goodies to try out!
There were a few examples provided in the release notes - thank you for that.
Other features' existence was only mentioned, with no "and here's how you'd use
that..." which can save LOTS of time and spark new ideas.
I was reading the changes, and at the moment was specifically interested in:
image metadata
tuple style variables
variable size arrays
and
render block size
I'm sure there are some pretty sweet other improvements that I missed while
skimming through it all :O
A big thanks to the POV development team for all of the continued fixes and
improvements :)
![](/i/fill.gif) |
![](/i/fill.gif) |
Am 25.01.2017 um 13:56 schrieb Bald Eagle:
> goodies to try out!
Did you try the docs?
> image metadata
Not much to say about this one, except what's stated in the docs:
"Most image formats now include metadata (BMP is a notable exception).
This metadata contains the POV-Ray version, render date/time (GMT),
platform (e.g. x86_64-pc-win), and compiler used to build the POV-Ray
executable."
The data is added automatically, with no way whatsoever for the user to
influence this.
BTW, this feature has already been present since 3.7.0.
Sorry to disappoint you, but there are /no/ tuple style variables (as in
`#declare Foo = (42,4711,"Frobnitz");`).
What have been added are tuple style /assignments/ (as in `#declare
(Foo,Bar,Fnord) = (42,4711,"Frobnitz");`), mainly as a means to allow
for macros to "return" multiple data items; e.g.:
#macro Compute()
#local A = 42;
#local B = 4711;
#local C = "Frobnitz";
(A,B,C)
#declare (Foo,Bar,Fnord) = Compute();
Details can be found in the "Declare and Local Directives" in the docs,
and the new incarnation of the `ior.inc` standard include file may serve
as an example of this mechanism. (*)
(* Well, it /could/ serve as an example if it wasn't broken, as I'm just
discovering right now.)
And of course there are dictionaries, but they're somewhat different
animals.
Easy as eating pancakes:
#declare Foo = array;
will give you a 1-dimensional array that grows automatically whenever
you access an element beyond the current size; e.g.
#declare Foo[3] = 42;
will increase the array size to 4 elements (0 to 3), leaving elements 0
to 2 undefined; and
#ifdef (Foo[4711]) ...
will increase the array size to 4712 elements (0 to 4711), which is not
really useful for anything but is a side effect of how this is implemented.
There are no multi-dimensional variable-size arrays.
There is no way to shrink a variable-size array.
> and
> render block size
The `Render_Block_Size=n`/`+BSn` parameter, too, has already been around
since 3.7.0.
Plenty of them! You didn't mention dictionaries, nor optional macro
parameters, nor function-based user-defined cameras, to name just a few ;)
We also have docs that are properly indexed again - yay! ;)
> improvements :)
You're welcome.
![](/i/fill.gif) |
