POV-Ray : Newsgroups : povray.advanced-users : Fitting image to view frustum Server Time
17 Nov 2025 18:49:33 EST (-0500)
  Fitting image to view frustum (Message 1 to 3 of 3)
Subject: Fitting image to view frustum
Date: 5 Dec 2016 12:30:01
Message: <web.5845a36e71f7f770c437ac910@news.povray.org>
I'd like to set up a scene that I'll be using a wide variety of images in, and
I'd like to be able to accurately and reliably fit the whole image to the screen
(image_map) when the scene is rendered, regardless of the dimensions - square,
wide and short, or tall and narrow.
I have something reasonably workable - but I was wondering if there was a
standard coding for this, given that so many software applications have some
sort of fit page / fit width option.
Thanks!
Subject: Re: Fitting image to view frustum
Date: 5 Dec 2016 16:20:03
Message: <5845da03$1@news.povray.org>
Am 05.12.2016 um 18:27 schrieb Bald Eagle:
If you want the output image format to also adapt, then you're out of luck.
Nope, nothing inbuilt at present.
Date: 6 Dec 2016 09:10:01
Message: <web.5846c5b1c8622f6cc437ac910@news.povray.org>
I can specify that in SDL
I just need a calculation to plug into the beginning of the scene or use as a
macro.
I'm currently using:
#declare Picture = pigment {image_map {png "Image.png"}}
#declare Resolution = max_extent (Picture);
#declare PictureScale = (Resolution + <0, 0, 1>);
camera {location <Resolution.x/2, Resolution.y/2, -max(Resolution.x,
Resolution.y)*1.5>}
