POV-Ray : Newsgroups : povray.advanced-users : How to address last 2 components of 5-component vectors? Server Time
30 Mar 2026 00:19:57 EDT (-0400)
  How to address last 2 components of 5-component vectors? (Message 31 to 40 of 46)
<<< Previous 10 Messages Goto Latest 10 Messages Next 6 Messages >>>
Subject: Re: How to address last 2 components of 5-component vectors?
Date: 10 Jul 2016 11:49:35
Message: <57826e8f$1@news.povray.org>
On 07/10/2016 11:30 AM, William F Pokorny wrote:
> On 07/10/2016 08:37 AM, Le_Forgeron wrote:
> OK. If the optionality is what we are trying to indicate, I think we
> probably want something like :
> COLOR_VECTOR:
>       [rgb] float            | (promoted to 3 value vector)
>       [rg0] <2 Term Vector>  |
>       [rgb] <3_Term_Vector>  |
>       [rgbf] <4_Term_Vector> |
>       rgbt <4_Term_Vector>   |
>       [ rgbft ] <5_Term_Vector> |
>       srgb <3_Term_Vector>   |
>       srgbf <4_Term_Vector>  |
>       srgbt <4_Term_Vector>  |
>       srgbft <5_Term_Vector>
> Bill P.
Argh... Just popped into my head the line:
is more like:
[rgb] <2 Term Vector>  | (blue is zero in this case)
there is of course no "rg0". :-)
Bill P.
Date: 10 Jul 2016 11:50:52
Message: <57826edc$1@news.povray.org>
Am 10.07.2016 um 17:30 schrieb William F Pokorny:
> COLOR_VECTOR:
Since floats and less-than-5-term vectors are automatically promoted to
5-term vectors this is not necessary. To the contrary, what you suggest
might be misinterpreted to imply that e.g. `rgbft <4_Term_Vector>` would
be invalid, when in fact it is perfectly legal.
Also, there is no `rg0` keyword, so that's plain nonsense right there.
Date: 10 Jul 2016 12:21:27
Message: <57827607$1@news.povray.org>
>> COLOR_VECTOR:
(Indeed. I'm about half nonsensical in any given moment. ;-) See my own,
earlier correction to rg0)
The block under discussion is in the section:
http://wiki.povray.org/content?title=Reference:Color_Expressions
where we describe how a user can specify color as in:
pigment { color .... }
In this context it seems to me we care not that a 5 term vector is
otherwise treated by POV-Ray as a color vector by default, but whether
we need to specify the rgb... whatever string in the color
specification. In the latter context I think what I have written is what
happens. All these are today valid ways to specify color:
color 1           // We get white
color <1,1>       // We get yellow
color <1,1,1>     // White
color <1,1,1,1>   // Clear by filter
color <1,1,1,1,1> // Again clear
Bill P.
Date: 10 Jul 2016 12:32:52
Message: <578278b4$1@news.povray.org>
>> COLOR_VECTOR:
>> Bill P.
> is more like:
> Bill P.
IMHO, you are missing that, at another level, the missing terms are automatically
created from existing input when needed.
float get promoted to 3D, 2D get completed to 3D with 0 as the last term and so on
(including 2D expended to 4D and 5D when needed)... but some too-short expression can
give you a warning (such as "Suspicious expression after rgbf.")
On the same line, providing a 5D for a 4D (e.g. rgbf) will also give you a warning
(that's not a promotion/extension, rather a reduction).
Yet, it is valid syntax. (even if the 5th term get ignored).
On the same line, when "<N_Term_Vector>" is used, it can be any expression (including
+,-,* and /... and even some within ?: ternary operator ) which result in such values,
at the end.
You are going to have very hard to have a readable syntax if you want to list all
possible cases for just "rgb xxxxx"
Date: 10 Jul 2016 13:04:16
Message: <57828010$1@news.povray.org>
Am 10.07.2016 um 18:21 schrieb William F Pokorny:
If you look at it that way, you forget
  color rgb 1
  color rgb <1,1>
  color rgb <1,1,1>
  color rgbf 1
  color rgbf <1,1>
  color rgbf <1,1,1>
  color rgbf <1,1,1,1>
  color rgbt 1
  color rgbt <1,1>
  color rgbt <1,1,1>
  color rgbt <1,1,1,1>
  color rgbft 1
  color rgbft <1,1>
  color rgbft <1,1,1>
  color rgbft <1,1,1,1>
  color rgbft <1,1,1,1,1>
  color srgb 1
  color srgb <1,1>
  color srgb <1,1,1>
  color srgbf 1
  color srgbf <1,1>
  color srgbf <1,1,1>
  color srgbf <1,1,1,1>
  color srgbt 1
  color srgbt <1,1>
  color srgbt <1,1,1>
  color srgbt <1,1,1,1>
  color srgbft 1
  color srgbft <1,1>
  color srgbft <1,1,1>
  color srgbft <1,1,1,1>
  color srgbft <1,1,1,1,1>
Also, you forget
  color rgb <1,1,1,1>
  color rgb <1,1,1,1,1>
  color rgbf <1,1,1,1,1>
  color rgbt <1,1,1,1,1>
  color srgb <1,1,1,1>
  color srgb <1,1,1,1,1>
  color srgbf <1,1,1,1,1>
  color srgbt <1,1,1,1,1>
which are also accepted (even though they raise a warning).
You don't really want to list all these special cases individually in
the syntax box for COLOR (or at least I /hope/ you don't want to ;)).
As for the factoid that "a 5 term vector is otherwise treated by POV-Ray
as a color vector by default", this is technically wrong.
The truth is that `.x`, `.y`, `.z` ect., as well as `.red`, `.green",
`.blue` etc., are all allowed for both vectors and colours, and both
colours and vectors can be used interchangeably, so the difference
between the two is pretty obscure (which is a property of POV-Ray's SDL
that I have always detested).
As for the `rgbft` being optional in a colour statement, this also does
/not/ mean that 5-term vectors are treated as colours by default.
Instead, it means that if the parser /specifically/ expects a colour, an
arbitrary vector is also legal (and is the very mechanism by which
vectors can be used in place of colours).
Date: 10 Jul 2016 13:43:52
Message: <57828958$1@news.povray.org>
Am 10.07.2016 um 13:03 schrieb Le_Forgeron:
> Le 10/07/2016 12:41, clipka a écrit :
>> Am 10.07.2016 um 05:16 schrieb Bald Eagle:
>>> (curious - Was .hf eliminated, or was it never implemented?)
>> In the 3.6 docs, it is only mentioned in the isosurface tutorial, where
>> it is labeled "experimental", and in the source code it is even labeled
>> as unofficial, for MegaPOV compatibility only.
>> In fact, `.hf` is only available within functions; also, it is intended
>> to produce an "experimental feature" warning (but currently doesn't).
> The code which set the flag is in comment in fncode.cpp ("// TODO
FIXME		Experimental_Flag |= EF_ISOFN;")
> Now, should it remains an experimental feature... I do not know.
The code is bogus (the constant 0.996093 in the formula is not only a
"magic" value, but most certainly wrong), so it sure as hell shouldn't
become canonical in its current form.
Date: 10 Jul 2016 14:32:39
Message: <578294c7$1@news.povray.org>
>>> COLOR_VECTOR:
>>> Bill P.
>> is more like:
>> Bill P.
(including +,-,* and /... and even some within ?: ternary operator ) which result in
such values, at the end.
(Christoph, I saw your response too, but will respond just here)
I think I generally understand the promotion and demotion going on when
colors are expected and we have various floats or vectors as the
starting point/right-hand-argument.
When I originally questioned the line:
it was because our saying rgbft was optional per the brackets in just
the five term vector case did not make sense to me for a syntax
specification.
That "...the missing terms are automatically created from existing input
when needed" is the point.
The rgb string is also optional for a float and multiple vector
specifications. Why is it we are not showing the user it is optional
with brackets as in [rgb], but doing it for rgbft and the 5 term vector
case?
It seems to me for a syntax specification for color vectors we should be
completely truthful about whether the string is optional, or always
vague, listing just the various ".rgb.." strings.
Bill P.
Date: 10 Jul 2016 14:50:55
Message: <5782990f@news.povray.org>
IIRC, the heigth field interpretation of the color (when coming from indexed picture)
was & is also bogus (kept as such for backward compatibility)
(0.996093 looks like 255/256 : .99609375000000000000000000000000000000000000000000)
(See imageutil.cpp, image_height_at() function, due to history an 8 bit value bbbbbbbb
is promoted into 16 bits as bbbbbbbb00000000, making 65535 an unreachable value;
Notice that 0xFF00 / 0x10000 is also the same magic value)
Looking at the code of fncode.cpp,
the operations would resume to (r+g/255)*255/256
For r=g=1.0 (max normal value), it result in 1.0 (also the expected max value).
Excepted that the constant is truncated at the 7th significant decimal digit, which is
also the usual precision of double.
So, it is probably always bad, but nobody would be able to see it at that precision,
and because it is truncated to a lower multiplier, there is no overflow, and rounding
error might get you a 1.0 (not tested).
Date: 10 Jul 2016 14:56:02
Message: <57829a42$1@news.povray.org>
Le 10/07/2016 20:50, Le_Forgeron a écrit :
>  which is also the usual precision of double.
My bad, 7th decimal digit is the precision of float, not double.
Date: 10 Jul 2016 17:01:11
Message: <5782b797$1@news.povray.org>
Am 10.07.2016 um 20:50 schrieb Le_Forgeron:
picture)
Yup. Not directly related though.
That's what I think, too.
