![](/i/fill.gif) |
So, I came across this earlier on today:
https://en.wikipedia.org/wiki/Spiral_of_Theodorus
and just wanted to play a bit with it.
Here's some code y'all can feel free to play with, though I can't quite seem to
get my rgb color to change on-screen, except for the very last triangle.
The debug stream shows the r and g components smoothly being decremented, so I'm
not sure what's going on.
I think there might be a nut loose somewhere between the chair and the
keyboard...
#version 3.7;
global_settings { assumed_gamma 1.0 }
// SDL for generating a Spiral of Theodorus
// Bill Walker - 2016
#include "debug.inc"
Set_Debug (true)
#include "math.inc"
#include "rand.inc"
#include "shapes.inc"
#include "metals.inc"
#include "transforms.inc"
#declare XImageSize = 1024;
#declare YImageSize = 768;
light_source { <0, 0, -max(XImageSize, YImageSize)*1.1> color rgb <1, 1, 1>}
#declare Camera_Origin = camera {
location <0, 0, 0>
//right x*image_width/image_height
look_at <0, 0, 0.01>}
#declare Camera_Angle = camera {
location <5 , 10, -15.0>
//look_at <0, 0, 0>
look_at <5, 5, 5>}
#declare Camera_Front = camera {
location <0, -0, -40>
look_at <0, 0, 0>}
#declare Camera_Rear = camera {
location <0.0, -100.0, -300.0>
look_at <0, 0, 0>}
#declare Camera_Top = camera {
location <0, 8.0, 0>
look_at <0, 0, 0>}
#declare Camera_Iso = camera {
location <-50, 0, 0>
look_at <0, 0, 0>}
#declare Camera_Bottom = camera {
location <0, -1, -0.1>
look_at <0, 0, 0>}
#declare Camera_Point = camera {
location <1.5, 0, -1>
look_at <1.5, 0, 0>}
camera {Camera_Front}
sky_sphere { pigment {Blue} }
#declare RGB = <255, 255, 0>;
#declare Color = texture {pigment {color rgb RGB}};
#declare Line1 = texture {pigment {Black}};
#declare Line2 = texture {pigment {color rgb RGB*0.2}};
#declare Line2 = texture {pigment {Blue}};
#declare NumberOfTriangles = 360; // <<===== CHANGE THIS TO MAKE SPIRAL BIGGER
OR SMALLER =
#declare CurrentTriangle = 0;
#declare Base = 1;
#declare Zvalue = 0;
#declare Corner_1 = <0, 0, 0>;
#declare Corner_2 = <1, 0, 0>;
#declare Corner_3 = <1, 1, 0>;
sphere {<0, 0, 0> 0.1 texture {Color}}
#while (CurrentTriangle < NumberOfTriangles)
// render current triangle
triangle {Corner_1, Corner_2, Corner_3 texture {Color}}
#declare Adj = VDist(Corner_1, Corner_2);
#declare Opp = VDist(Corner_2, Corner_3);
#declare Hyp = VDist(Corner_1, Corner_3);
#declare SQRbothSides = pow (Adj, 2) + pow (Opp, 2);
#declare Calc = sqrt (SQRbothSides);
#debug concat( "Hypotenuse length = ", str(Hyp, 5, 5), " Formula = SQRT (",
str(SQRbothSides, 5, 1), ") Calculated Value = ", str(Calc, 5, 5), " RGB = ",
vstr(3, RGB, ", ", 3, 1), " \n")
//#debug concat( "RGB = ", vstr(3, RGB, ", ", 3, 3), " \n")
cylinder { Corner_2, Corner_3, 0.05 texture {Line1}} // Spiral line
cylinder { Corner_1, Corner_3, 0.02 texture {Line2}} // Segment divider lines
// compute attrubutes for next triangle
#declare Perp = VPerp_To_Plane(z, Corner_3); // returns a vector perpendicular
to the hypotenuse (and z-axis) *** relative to origin ***
#declare Corner_2 = Corner_3; // New right angle vertex is the old
"hypotenuse vertex"
#declare Corner_3 = Corner_3 + Perp; // new "hypotenuse vertex" is
translated perpendicular to the hypotenuse by 1 unit by simple vector addition
// shift new triangle back a bit to avoid Coincident Surfaces
#declare Zvalue = Zvalue + 1;
#declare Corner_1 = Corner_1 + <0, 0, 0.001>;
#declare Corner_2 = Corner_2 + <0, 0, 0.001>;
#declare Corner_3 = Corner_3 + <0, 0, 0.001>;
// change color
#declare RGB = RGB - <255/NumberOfTriangles, 255/NumberOfTriangles, 0>;
#declare CurrentTriangle = CurrentTriangle + 1;
#end // end while loop
![](/i/fill.gif) |
