POV-Ray : Newsgroups : povray.advanced-users : shape3.inc Error Server Time
17 Nov 2025 20:41:45 EST (-0500)
  shape3.inc Error (Message 1 to 4 of 4)
Subject: shape3.inc Error
Date: 25 May 2015 11:00:00
Message: <web.55633836be046037eaf54a820@news.povray.org>
I am taking reference of simple example which uses 'shapes3.inc'.
But when I compile my file I got error as
File Context (5 lines):
#include "shapes3.inc"
Parse Error: Cannot open include file shapes3.inc.
File: particale.pov  Line: 2
Parse Warning: Check that the file is in a directory specifed with a +L switch
 or 'Library_Path=' .INI item. Standard include files are in the include
 directory or folder. Please read your documentation carefully.
I know I have to edit .ini file but how to solve it?
Subject: Re: shape3.inc Error
Date: 25 May 2015 11:33:51
Message: <556340df$1@news.povray.org>
Hash: SHA256
> File Context (5 lines): #include "colors.inc" #include
> "shapes3.inc" Parse Error: Cannot open include file shapes3.inc.
> File: particale.pov  Line: 2 Parse Warning: Check that the file is
> in a directory specifed with a +L switch or 'Library_Path=' .INI
> item. Standard include files are in the include directory or
What system are you on ?
If unix/linux, did the system adminstrator ran "make install" so that
the include files get installed in /usr/local/share/povray-3.7/include ?
If windows, I do not know.
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2
iJwEAQEIAAYFAlVjQOEACgkQhKAm8mTpkW1FQQQAzueFUlQOA9IHkBf6FMYfuVzN
OUb2UPQU+mdi6S4Gnk6bB7MoYu01sRzrmibwdAxFRkj/MgEQ2UfzdpyFv88EpWQV
+KDnAQpuvZwzur3RSbenuY74x4W6nYE5oKOCLF0R8xCm8hqZHgcCN1A35n19xIEE
d60bpxZOtogc/po1DfA=
=6RgD
-----END PGP SIGNATURE-----
Date: 25 May 2015 13:20:01
Message: <web.55635906585fc98b7a3e03fe0@news.povray.org>
If colors.inc is defined, probably the shapes3.inc file isn't present anywhere.
What povray version? If RC, shapes3.inc isn't present in a set.
Date: 27 May 2015 11:26:46
Message: <5565e236$1@news.povray.org>
I just checked my "include" folders for version 3.6 and 3.7, and it
turns out that "shapes3.inc" is found in version 3.7 but not in 3.6.  Is
it possible that you've opened a version 3.7 scene file with POV-Ray 3.6?
--Sherry Shaw
#macro T(E,N)sphere{x,.4rotate z*E*60translate y*N pigment{wrinkles scale
.3}finish{ambient 1}}#end#local I=0;#while(I<5)T(I,1)T(1-I,-1)#local I=I+
1;#end camera{location-5*z}plane{z,37 pigment{granite color_map{[.7rgb 0]
[1rgb 1]}}finish{ambient 2}}//                                   TenMoons
