POV-Ray : Newsgroups : povray.advanced-users : use_alpha and hierarchy Server Time
14 Mar 2026 12:56:50 EDT (-0400)
  use_alpha and hierarchy (Message 1 to 2 of 2)
Subject: use_alpha and hierarchy
Date: 23 Oct 2014 15:40:02
Message: <web.544958848419c90d5e7df57c0@news.povray.org>
I'm having a bit of difficulty structuring my texture statement for a
black&white frame.  I'm guessing that I somehow need to use "use_alpha", and
then have another level of the hierarchy specify the mapping of the textures for
the black and white regions of the image.
NOT using the use_alpha keyword and just texture_map from 0.01 to 1 didn't seem
to quite give me what I wanted.  I still seem to be experiencing a bit of
confusion with all the different map types and how to structure them.
Can anyone jump in with an explanation, or some example code?
Thanks!
#declare ImageMap =
     image_pattern { png "AlphaMirror2.png" use_alpha once}
  texture_map {
   [0.00 texture_map {
    [0.00 pigment {Black}]  //  DullGold]
    [1.00 pigment {White}]  //  DullGold]
   [1.00 pigment { transmit 1 }]]
Subject: Re: use_alpha and hierarchy
Date: 23 Oct 2014 23:43:48
Message: <5449caf4$1@news.povray.org>
Am 23.10.2014 21:35, schrieb Bald Eagle:
> Thanks!
> #declare ImageMap =
> texture {
>    texture_map {
>     [0.00 texture_map {
What pattern is this texture_map supposed to be using?
Extraneous closing bracket.
Presuming that "AlphaMirror2.png" is a greyscale image with additional
transparency information, you're actually /almost/ there; the code
should look something like this:
     image_pattern { png "AlphaMirror2.png" use_alpha once }
     texture_map {
       [0.00
         image_pattern { png "AlphaMirror2.png" once }
         texture_map {
           [0.00 pigment { Black }]
           [1.00 pigment { White }]
Each texture_map needs its own pattern statement; "use_alpha" takes the
pattern information from the image's alpha channel, while the normal
image_pattern takes the pattern information from the image's greyscale
value.
