POV-Ray : Newsgroups : povray.advanced-users : Randomly timed events Server Time
8 Feb 2026 11:19:57 EST (-0500)
  Randomly timed events (Message 1 to 7 of 7)
Subject: Randomly timed events
Date: 29 Aug 2013 08:25:00
Message: <web.521f3cdb71b5bb97dd2ebc560@news.povray.org>
I'm trying to do a quick and dirty simulation of lightning flashes with
momentarily appearing point light_sources in a scene, and it appears that I
don't get any flashes except coincidentally and suspiciously in what appears to
be the very last frame.
All I'm doing right now is
#if (Flash = clock)
light_source { < rand(FlashX), rand(FlashY), rand(FlashZ) > color rgb <1,1,1> *
rand(Brightness) }
I'm thinking that I need to "open the window" of where the random value and the
clock coincide to increase the probability of a flash - although I'm concerned
that my lack of insight into pseudo-random numbers in POV-Ray might doom me to
pre-destined failure here...  (See other thread on random placement of objects)
Has anyone worked with this type of thing before?
Helpful suggestions?
Subject: Re: Randomly timed events
Date: 29 Aug 2013 09:16:50
Message: <521f49c2$1@news.povray.org>
> #if (Flash = clock)
> rand(Brightness) }
> #end
How are you defining the variables Flash, FlashX, FlashY, FlashZ,
Brightness?
Date: 29 Aug 2013 10:15:01
Message: <web.521f5729fc2c9d36dd2ebc560@news.povray.org>
> Brightness?
#declare Flash = seed (1);
#declare Brightness = seed (2);
#declare FlashX = seed (3);
#declare FlashY = seed (4);
#declare FlashZ = seed (5);
Date: 29 Aug 2013 10:55:58
Message: <521f60fe$1@news.povray.org>
>> Brightness?
There is no real reason to create a separate seed for every random
variable, you can just keep calling rand() on the same seed and it will
keep generating new random numbers.
I guess you probably meant to write:
#if( rand(Flash) = clock )
But that won't work as you want, because rand() returns a float between
0 and 1 and it's extremely unlikely to ever equal your clock value. If
you want your flash to last just one frame try something like:
#declare Flash = seed(1);
#declare flashFrame = int( rand(Flash) * final_frame);
#if( frame_number = flashFrame)
Or if you want your flash to last a specific amount of clock (eg 0.1):
#declare flashStart = rand(Flash) * final_clock;
#if( clock>flashStart & clock<flashStart+0.1)
Note this will create the flash at exactly the same frame every time you
run the animation - because the first random number generated after
seed(1) is always the same.
Date: 29 Aug 2013 11:35:01
Message: <web.521f69a1fc2c9d36dd2ebc560@news.povray.org>
Oops.  Late-night POV coding strikes again.
Yes, that's what I was worried about, and with some food and coffee fueling the
brain, I can likely see just how probable the unlikelihood of the clock and
random number probably, or improbably matching is, or isn't.  Though that could
change.  :D
>If  you want your flash to last just one frame try something like:
_Most_ excellent.  That instantly cleared up that little problem.
I think if I consider the pseudorandom numbers as simply a library of selctable
one-dimensional arrays, it will be less confusing than "Hey, I need a 'random'
number" - because they're NOT.
I was also considering defining an object such as an image_map of noise, or a
cloud, and then just grabbing a pixel value, though I don't know if adding
layers of convolution get me anything better than declaring the seed value for
each frame with the clock value...  #declare RanDUMB_Number = seed (clock)
Date: 29 Aug 2013 11:44:32
Message: <521f6c60$1@news.povray.org>
I think (I could be wrong) but it's better to think of it as just one
huge one-dimensional circular array (that wraps back to the start once
you get to the end). The different seeds will just get you started at
different points in the array.
Using "frame_number" rather than "clock" would be better, as AFAIK the
seed function takes the integer part only.
Date: 29 Aug 2013 13:15:01
Message: <web.521f8153fc2c9d36e426a2320@news.povray.org>
[snip]
I did a scene with lightning flashes, a few years ago. I wanted the flashes to
appear at the correct place in the animation. So they were not random. I did
find that single flash in one frame was singularly unimpressive. So I made each
flash consist of several lit frames followed by a gap then several more.
As for trying to get rand and clock to match up. Best of luck there. ;-)
The variable final_frame is useful in these occasions to give you a way of
working out where in the animation your flashes will be.
