POV-Ray : Newsgroups : povray.advanced-users : Array initializer versus macros - syntax error Server Time
18 Nov 2025 00:36:56 EST (-0500)
  Array initializer versus macros - syntax error (Message 1 to 6 of 6)
Subject: Array initializer versus macros - syntax error
Date: 1 Mar 2012 17:15:01
Message: <web.4f4ff3ab1a931bd7f281f53a0@news.povray.org>
This may not be a bug, but it is certainly confusing me (easier to do these
days)...
This is using POV-Ray 3.7 RC4 on Mac, but is likely a language issue on all
platforms.  I have poked through the docs and POV-Wiki to no avail.
I'm starting to play with pre-creating arrays of texture elements, and writing
macros to help pre-build color-maps for them.  I've done this successfully with
certain elements (for example "pigment").  But I cannot do the same construct
for the "color_map" element.  Here's a boiled down scene file that will cause a
syntax error:
// POV-Ray 3.7 file that gives a syntax error when using a macro to init an
array element
#version 3.7
// define a Macro that creates a color_map
#macro ColorMapMacro(lineColor)
color_map
 [ 0.0 color rgb 0 ]
 [ 0.5 color rgb lineColor  ]
 [ 1.0 color rgb 0  ]
// create a local color_map variable from the macro, this works fine
#local localCM= ColorMapMacro(<1,1,1>);
// declare an array of color_maps
#local ColorMapArray1 = array[3];
// now MANUALLY initialize each element in 3 different ways
#local ColorMapArray1[0] =  color_map
 [ 0.0 color rgb 0 ]
 [ 0.5 color rgb 1  ]
 [ 1.0 color rgb 0  ]
#local ColorMapArray1[1] =  localCM;
#local ColorMapArray1[2] =  ColorMapMacro(<1,1,1>);
// Do the same thing, but this time use the inline array initializer syntax
#local ColorMapArray2 = array[3]
 color_map
 [ 0.0 color rgb 0 ]
 [ 0.5 color rgb 1  ]
 [ 1.0 color rgb 0  ]
 localCM,
// "Parse Error: Attempted to redefine colour map identifier as object
identifier."
What part of the POV-Ray language syntax am I missing here?  Can't an array
element be initialized from a macro?  Isn't it just magically injecting a
color_map declaration there?
I am poised with my hand hovering over my forehead, for the upcoming slap. :-)
ttfn,
Eduard
POV-Ray Mac Developer - Emeritus
www.schwansongs.com
Subject: Re: Array initializer versus macros - syntax error
Date: 1 Mar 2012 23:43:05
Message: <4f504fd9$1@news.povray.org>
>   color_map
>   [ 0.0 color rgb 0 ]
>   [ 0.5 color rgb 1  ]
>   [ 1.0 color rgb 0  ]
>   localCM,
> identifier."
Hello Eduard!
The error message is really funny, isn't it?  The reason is as trivial as
the explanation Chris Young wrote for the docs: "POV-Ray macros are a
strange mix of macros and functions." in
<http://www.povray.org/documentation/view/3.6.1/243/#s02_02_02_08_03> .
And you happen to catch the macro in a case where the macros behaves like a
function. It returns an object identifier of type "color_map", but too bad
for you, it isn't a scene-level object, but one of those special cases that
isn't really an object internally. As the docs (knowing this was written by
Chris Young) say "When the body of a macro consists of statements that
create an entire item such as an object, texture, etc. then the macro acts
like a function which returns a single value." So when you try to assign it
to the array, the code thinks you are assigning a (scene-level) object to
the array of the special type of color_map" objects. It would need to do
more inspection here, but that isn't happening.
Honestly, I didn't even know (!!!) it was possible to assign color_map
objects to arrays before looking into the code, but it is also pretty clear
that fixing the color_map assignment might not be trivial (though I haven't
stepped through the code just yet). Especially given color_map code tends to
leak so quickly and in so many unusual cases.
Of course, this does not solve the problem at hand, but: You might try to
declare the return value of the macro locally, and then return that value.
This might work...
As for fixing this in 3.7, it probably isn't a good idea to mess with the
parser at this stage and on this level. But filing a bug report might be a
good idea ;-)
Thorsten
Date: 2 Mar 2012 09:15:01
Message: <web.4f50d4c3c0fcd54d2693ad740@news.povray.org>
> Hello Eduard!
> This might work...
> good idea ;-)
> Thorsten
Hi there Thorsten!
I had read and re-read that macro section, and tried altering the macro in a
number of ways before giving up and writing this plea for help :-)  Chris's
general paragraph there has hints, but I was still not sure if this could be
considered a bug... so I was not ready to write a bug report (and definitely not
for a 3.7 fix!)
On the other hand, I cannot see an easy way to get what I want... that is, a way
to create an array of color_maps, and an array of pigments without color_maps,
so that I can choose a random color_map from the array to inject into a random
pigment from another array in my scene.
I did know that arrays of pigment{} will work, so I thought I could instead
pre-create the pigment statement I want (without a color map) and pass that into
the macro as a parameter, and the macro could ADD a new color_map and wrap the
whole thing in a new pigment element... but that doesn't let me mix and match
pigments and different color-maps.
I will ponder this more.  But thank you for responding and explaining that
color_map is not the same first-class scene-object-citizen that pigment is.
That makes sense in my programmer brain, but not in my end-user brain :-)
Eduard
Date: 2 Mar 2012 14:07:32
Message: <4f511a74@news.povray.org>
  Did you try what Thorsten suggested, ie. declaring a local identifier
and "returning" it from the macro? In other words, like:
  #local ColorMap =
    color_map
      [ 0.0 color rgb 0 ]
      [ 1.0 color rgb 0  ]
  ColorMap
  (Haven't tested it myself to see if it works...)
Date: 3 Mar 2012 09:15:00
Message: <web.4f52273ac0fcd54d2693ad740@news.povray.org>
>   #local ColorMap =
>     color_map
>       [ 0.0 color rgb 0 ]
>       [ 1.0 color rgb 0  ]
>   ColorMap
> #end
Sorry about the delay, real life keeps interrupting my render sessions!  Yes, I
tried it and it did NOT fix the problem.
However, I have found a slightly less-pretty workaround, so I will be using that
for now.  That is as I mentioned above, for some reason if I use explicit
initialization of each array element, it works.  It is just the
auto-initialization that fails... but that means I'll have to write it this way:
color_map
 [ 0.0 color rgb 0 ]
 [ 1.0 color rgb 0  ]
maintain :-)
#local ColorMapArray1[0] =  ColorMapMacro(<1,1,0>);
#local ColorMapArray1[1] =  ColorMapMacro(<1,0,1>);
#local ColorMapArray1[2] =  ColorMapMacro(<0,1,1>);
But, this gets me back on my way.  Thank you both for your clarifying help.
ttfn,
Eduard
Date: 4 Mar 2012 15:49:46
Message: <4f53d56a$1@news.povray.org>
How about calling this in a loop based on a vector or color array?
