![](/i/fill.gif) |
Thank you all again. I have incorporated a custom function to work around
POV-Ray 3.6.1's radiosity bug, and to greatly improve both the quality and the
render speed. Here is what I've settled on for now, while I render it from
various angles to get a better sense of it:
// Copyright (C) 2011 by Peter Markley.
#local sun_radius = 40.00; // units in megameters
#local eith_orbt_rdus = 3000.00; // eithalica's orbit radius
#local aphelion_offset = 20.00; // distance of ephelion from
// otherwise circular orbit
#local eith_radius = 6.53; // eithalica is the planet's name
#local eith_mass = 6.40e24; // units in kilograms
#local eith_moon_dist = 6.00; // dist @ closest point between
// eithalica's & moon's surfaces
#local eith_moon_rdus = 6.22; // moon radius
#local eith_moon_mass = 5.55e24; // moon mass
#local eith_rotn_prod = 4.70; // rotation period in hours
#local camr_dist = 3.00; // multiplier for camera dist
#local eith_poso = radians(073); // eithalica's orbital position
// in radians counterclockwise
// from positive x axis
#local eith_day = (10/(141+1))*4.70;//(frame_number/(final_frame+1))*4.70;
// eith's rotational position in
// hours - one full turn every
// multiple of 4.70
#local atmos_color = <5.4e-2,1.8e-1,3.6e-1>; // color that is reflected
//#local atmos_twilight = 1-(1-<1.0,0.7,0.4>)*1.0; // color that is transmitted
#local eith_moon_posr = eith_radius+eith_moon_dist+eith_moon_rdus;
#local eith_rotn = (eith_day/eith_rotn_prod)*-360-degrees(eith_poso);
#local eith_posx =
cos(eith_poso)*(eith_orbt_rdus+aphelion_offset*0.5)-aphelion_offset*0.5;
#local eith_posz = sin(eith_poso)*eith_orbt_rdus;
camera
location <0,1,-0.1>*(eith_moon_posr+eith_moon_rdus)*(camr_dist+1.0) look_at 0
rotate <0,eith_rotn,0>
translate <eith_posx,0,eith_posz>
angle 48
light_source
0 color rgb 3.0
/*looks_like
sphere
0,sun_radius
texture {pigment {rgb 5} finish {ambient 1}}
no_shadow
sphere
0,1e2
texture {pigment {rgbt <0,0,0,1>}}
no_shadow
hollow
interior
media
emission <1.0e-2,5.0e-3,7.0e-4>
intervals 1
method 3
samples 20
sky_sphere {pigment {rgb <0,0,0>}}
global_settings
ambient_light 1.0
radiosity {brightness 1.0 count 100 media on recursion_limit 20}
max_trace_level 15
#default {finish {ambient 0.0 diffuse 1.0}}
/*torus {eith_orbt_rdus,0.5 texture {pigment {rgb <1,0.3,0>} finish {ambient
1}}}
torus
eith_orbt_rdus,0.5 texture {pigment {rgb <1,1,0>} finish {ambient 1}}
scale <(aphelion_offset*0.5+eith_orbt_rdus)/eith_orbt_rdus,1,1>
translate <-aphelion_offset*0.5,0,0>
#local eith_texture = texture
pigment {rgb <0,0,0.4>}
finish {specular 0.7}
normal {agate scale 1e-3}
union
// eithalica
union
sphere
0,eith_radius texture {eith_texture}
texture {pigment {image_map {png "./eithalica_tex.png" map_type 1}}}
photons {target reflection on refraction off}
sphere
0,eith_radius+8e-2
texture {pigment {image_map {png "./eithalica_clouds.png" map_type 1}}}
hollow
// temalar
union
sphere
0,eith_moon_rdus texture {eith_texture}
texture {pigment {image_map {png "./temalar_tex.png" map_type 1}}}
sphere
0,eith_moon_rdus+8e-2
texture {pigment {image_map {png "./temalar_clouds.png" map_type 1}}}
hollow
translate <eith_moon_posr,0,0>
// chessol
union
sphere
texture {pigment {image_map {png "./chessol_tex.png" map_type 1}}}
sphere
texture {pigment {image_map {png "./chessol_clouds.png" map_type 1}}}
hollow
rotate <0,-120,0>
// siothum
union
sphere
texture {pigment {image_map {png "./siothum_tex.png" map_type 1}}}
sphere
texture {pigment {image_map {png "./siothum_clouds.png" map_type 1}}}
hollow
rotate <0, 120,0>
//torus {eith_moon_posr,0.1 texture {pigment {rgb <1,1,0>} finish {ambient 1}}}
#local mlef = -cos(radians(60))*eith_moon_posr;
#local mrht = eith_moon_posr;
#local mbot = -sin(radians(60))*eith_moon_posr;
#local mtop = +sin(radians(60))*eith_moon_posr;
//chessol = <left,0,top>;
//siothum = <left,0,bottom>;
//temalar = <right,0,0>;
#local grav = 6.6738480e-29; // universal gravitational constant in cubic
megameters per (kilogram (seconds squared))
#local maxi = 13e-6; // maximum expected acceleration in megameters per second
#local mini = 7e-6; // acceleration threshold at which atmospheric density is
zero
#local len = function(x,y,z) {sqrt(pow(x,2)+pow(y,2)+pow(z,2))}; // distance
formula
sphere
0,eith_moon_posr+eith_moon_rdus*1.6 texture {pigment {rgbt <0,0,0,1>}}
hollow
interior
media
scattering {2, atmos_color extinction 1.6}
density
average
density_map
[0.25 function
1.0-min(1,1.0-(grav*eith_mass/pow(len(x,y,z),2)+
grav*eith_moon_mass/pow(len(x-mlef,y-0.0,z-mtop),2)+
grav*eith_moon_mass/pow(len(x-mlef,y-0.0,z-mbot),2)+
grav*eith_moon_mass/pow(len(x-mrht,y-0.0,z-00.0),2)-mini)
/(maxi-mini))
[1.0 function
(1.0-min(1,pow((sqrt(pow(x,2)+pow(y,2)+pow(z,2))-eith_radius)/(eith_radius*0.25),1/3)))+
(1.0-min(1,pow((sqrt(pow(x-mlef,2)+pow(y-0.0,2)+pow(z-mtop,2))-eith_moon_rdus)/(eith_moon_rdus*0.25),1/3)))+
(1.0-min(1,pow((sqrt(pow(x-mlef,2)+pow(y-0.0,2)+pow(z-mbot,2))-eith_moon_rdus)/(eith_moon_rdus*0.25),1/3)))+
(1.0-min(1,pow((sqrt(pow(x-mrht,2)+pow(y-0.0,2)+pow(z-00.0,2))-eith_moon_rdus)/(eith_moon_rdus*0.25),1/3)))
intervals 1 method 3 samples 20
//fade_color atmos_twilight
//fade_distance eith_moon_rdus*2.0
//fade_power 2.0
![](/i/fill.gif) |
![](/i/fill.gif) |
"Quartz" <qua### [at] malexmedia net> wrote:
> Thomas de Groot <tho### [at] degroot org> wrote:
> > On 21-3-2014 19:53, Quartz wrote:
> > > The following link is by no means a step toward syndication of real content, but
> > > it gives a glimpse of my eventual goal.
> > > http://youtu.be/ybbZG8cXI3A
> > Makes one curious to see more of this :-)
> > Thomas
> I treasure this type of encouragement. Thank you!
> I've just finished a rough draft of the Eithalica story, and will soon forge
> ahead creating content. I'll surely keep my POV-Ray Newsgroup friends informed.
> I always hate making people wait when they show appreciation for my work. ;-)
Hello again POV-Ray friends,
Thank you again for your prior encouragement. The word "soon" may have been
premature, because in 2015 I still had no peer critiques on the draft! Lack of
peer critique has no doubt spoiled the potential of countless would-be geniuses
through the ages, and I'm only grateful to be aware of it myself.
In spite of endless delays, rest assured that Eithalica is neither abandoned nor
even losing momentum. If anything (no matter how slowly) it is still gaining
momentum.
In the past 3 years I have performed two major rewrites to the story, and my
peer(s) tell me that there likely need not be a third. I am hoping to finish
editing/revising the script sometime in 2019.
Allow me also to dispel some prior vagueness. Eithalica will be an epic graphic
novel (in 3 parts as it turns out), and when the script is finished I'll
officially begin illustration.
In observance of my writing progress, I have finally polished this POV-Ray scene
to my satisfaction. It is now a participant in the CGTrader Digital Art
Competition. Voting for it at the link below is welcome but not expected (I have
no delusions that I'll win the Public award).
https://www.cgtrader.com/digital-art-competition/gallery/5853/eithalica-quadruple-planet
I have purchased the domain http://eithalica.world/ and will soon put official
information there. Admins permitting, I may still post in this newsgroup a few
more times, but I can now refer anyone interested to the proper domain.
Various lesser concept art so far can be found with the hashtag #Eithalica on
Instagram, Twitter, Facebook, and DeviantArt, as well as the current redirection
target of eithalica.world (my professional portfolio).
https://www.instagram.com/explore/tags/eithalica/
https://www.deviantart.com/tag/eithalica
A few more details:
The rewrites I mentioned have all but invalidated the YouTube video from 2015.
(I switched main characters! The previous main character is all but written
out.) The genre is still sci-fi / high fantasy, and I now have a blurb (such as
you'd find on a back cover):
> On Eithalica, time sleeps beneath a sky of tree-leaves, and men of strange
> tongue walk with Yalengem, a race of luminescent sages.
> Neither squire Lorkan nor his Yalengem friend, Niavai, know how to restore
> peace to their war-torn kingdom, or calm the ailed groaning of the forest. But
> Niavai is sure the long lost Chetnum Empire knew - by warding off the spirits
> lurking in the shadows.
> When the spirits rise to snare Eithalica in living nightmares, Lorkan
> resolves to follow Niavai and recover the ancient knowledge. But their search
> becomes a pathless suffering in enemy lands on a distant moon; a titanic
> strain on Lorkan's will, and on his faith in Yalengem.
Thanks again for your help and interest! God bless.
![](/i/fill.gif) |
