POV-Ray : Newsgroups : povray.advanced-users : Invisible Photon Mapping Server Time
1 Jul 2024 03:43:05 EDT (-0400)
  Invisible Photon Mapping (Message 11 to 20 of 30)
Subject: Re: Invisible Photon Mapping
Date: 4 Sep 2011 19:30:00
Message: <web.4e640925c559cf212b8e18870@news.povray.org>
Oh, and please note that the subject matter ("eithalica," the quadrupal planet)
POV-Ray has about posting copyrighted material on the newsgroup, but a thousand
thanks for your help with my scene settings.
Date: 5 Sep 2011 03:54:33
Message: <4e648039@news.povray.org>
Care to elaborate a bit on "eithalica"? Cannot be found on Google...
(just curious)
Date: 5 Sep 2011 12:30:44
Message: <4e64f934@news.povray.org>
> Alain<aze### [at] qwertyorg>  wrote:
>> Why is your sun and planets both at coordinate 0?
> The planet[s] should be in a union that's translated at the end.
Then, during the devlopment phase, place your sun some distance away.
That way, the radiosity contribution will be visible and not totaly
hiden by the direct illumination.
>> With 3.6.1, there was a bug in radiosity: The recursion level had to
>> take transparent surfaces into consideration. You have 4 athmospheric
>> layers and recursion_level default to 3. Then, you have two sets of
>> layers plus the actual surface, for a total of 9.
> Excellent! I think you've hit upon it, Alain! Thank you.
Another reason to use version 3.7...
>> That said, I realy think that you should use only one athmospheric shell
>> containing only scattering media. You then modulate the density of that
>> media as needed, using the spherical pattern scalled to the radius of
>> the athmonsphre or some custom function.
> Oh, I didn't realize we had a spherical pattern before! I will definitely
> investigate.
>> fade_power 10? for your athmosphere?
>> A realistic fade_power is 1 for substances to use linear fading, or 1001
>> to use the exponential formula.
>> Test without fading gives beter results.
>> It's fade_power 2 for a fading light_source.
> This was to replace extinction, because I wasn't artistically satisfied with
> realistic results. Still willing to work on that; I probably just didn't have it
> configured correctly.
> Thanks a lot, everyone! I might post more on this later, but my initial question
> has been answered.
Just a note about the spherical pattern:
It's centered at <0,0,0>
It's value is 1 (rgb<1,1,1>) at the origin and drop to zero at a radius
of 1, then stay to zero everywhere.
There is also the onion pattern. It's a spherical gradient pattern.
Start at zero at the origin and climb up to 1.
In your scene, you have a merge of all your athmospheric shells
containing a single media.
You need to give an individual shell to each planet, apply the spherical
pattern then place them into position.
Adjust the colour_map for the pattern to be 1 at the planetary surface
and drop to zero at the very top of the shell.
Something like:
color_map{[Planet_Radius/Athmosphere_radius rgb 1][0 rgb 0]}
It's normal to take some artistic liberties when you model something
that is physicaly impossible. That quadruple planet just can't exist,
the center planet may survive, but the 3 moons would be ript apart by
the gravitational gradient and degenarate into a massive ring of
debrits. Think Saturn's rings, but about 10000 to 1000000 times denser.
Date: 5 Sep 2011 14:40:00
Message: <web.4e651734c559cf212b8e18870@news.povray.org>
> (just curious)
> Thomas
I believe it appears in the comments in my scene code, and in the filenames of
some of the bitmaps used. Other copyrighted fictional names appear in the code
also.
Date: 5 Sep 2011 15:00:00
Message: <web.4e651b3cc559cf212b8e18870@news.povray.org>
By "the end" I meant the end of the file or scene script, not the end of
development. The light source is very far away already, it's just also very
bright.
Indeed. I am hoping soon to look into what it would take to upgrade on Mac OS X
Lion.
Thanks! So I read in the documentation.
Unfortunately, although this is very close to what I need, it won't give a
realistic exponential die-away curve like we see in earth's atmosphere:
http://en.wikipedia.org/wiki/Atmosphere_of_Earth#Pressure_and_thickness
I may need a custom function after all, but that is beyond my current
experience. I love learning new things, but it'll be a bumpy ride! ;)
You're thinking of Roche's limit:
http://en.wikipedia.org/wiki/Roche%27s_limit
It's actually very interesting that you bring this up, because this was a
serious concern of mine when designing the planetary system. I worked out all
the physics according to my knowledge, and I think it could theoretically work.
Note that the planets make one full rotation (one day) in about 5 hours (4.70
hrs in my scene script). The system spins far, far faster than earth does, in
order to compensate for the greatly increased gravity.
When redesigning the bitmaps for the cloud layers, I'm going to have lots of fun
with the meteorological ramifications of a massively larger Coriolis effect,
among other things.
Again, this is all copyrighted by me, and thank you all so much for indulging
me! :)
Date: 5 Sep 2011 15:05:01
Message: <web.4e651d36c559cf212b8e18870@news.povray.org>
> > (just curious)
> > Thomas
> also.
ever published any of it. Above, I mistakenly put the date that I invented it
and wrote it down.
Date: 5 Sep 2011 15:45:00
Message: <web.4e652629c559cf212b8e18870@news.povray.org>
> Lion.
Uh-oh, looks like I'll have to compile from source if I want that to work...
Does that sound right?
Date: 5 Sep 2011 20:47:36
Message: <4e656da8@news.povray.org>
Yes.
Anyway, those planets would be heavily distorted by the mutual
gravitational pull.
The main planet would get strongly flatened at the poles and would
probably show proeminent bulges toward the moons.
The moons would be ove shaped with the small end toward the main planet.
(version 3.7 have an ove primitive)
The athmosphere can realisticaly connect all 4 worlds, allowing you to
fly, or float, from one world to the other.
If the 4 planets have the same mass and density, the actual limit may be
shorter, and the 2 oposite ones may help stabilise the third. But that
system still looks fictional...
Yep! Tidal lock between 4 bodies.
> among other things.
> me! :)
Date: 6 Sep 2011 01:00:08
Message: <web.4e65a874c559cf212b8e18870@news.povray.org>
> gravitational pull.
Yes, adding slight oblateness to the main planet and prolateness to its moons is
on my to-do list.
According to my calculations, at the surface of each planet/moon, the
acceleration due to gravity would not be too much less than on earth, in which
case the gap is far too large for a person to jump by themselves.
I'm not sure what the "escape velocity" would be though, because the gravity
falloff is greatly exaggerated from the norm by the body on the other side.
Perhaps a rocket would not be necessary.
Of course I've never heard of NASA discovering a system like this in real life,
but I did try to be very careful in my calculations.
Would you like me to post the POV-Ray script for a simulation I did in order to
determine the free-fall acceleration in such a system?
Date: 6 Sep 2011 03:04:15
Message: <4e65c5ef$1@news.povray.org>
On 5-9-2011 21:04, Quartz wrote:
> and wrote it down.
I see. Somewhat off topic but still curious: Do you intend to publish
your work in some official way? Otherwise I wonder why you insist on
copyright here. All/most scenes by all posters here are original works
and - implicitly according to ruling etiquette - we acknowledge code
from others when used. Or am I hopelessly naive? ;-)
